Drives: 2014 White FRS
Best tire fitment 18 x 9.5 +35
Hello,
Just wondering what might be the best fitment to fill in the wheel gap with TRD springs (1" drop) and 18x9.5+35 wheels. Currently on 245/35/18 tires but wheel gap seems little big and tires little stretched The current front setup has around half a finger gap before rubbing the suspension Would a 255/35/18 rub? Or a 245/40/18 do the trick? Or 235/40/18?... Not in a rush for tires, just getting advice for when my current tires need replacement Thank you Last edited by golemslord; 06-21-2020 at 12:18 PM. |
#2 | |
Drives: 2015 BRZ
#3 | |
Drives: 2019 Toyota 86 TRD SE
245 is consider stretched already for 9.5"? Any negative for this? I plan to run 245/35/18 or 245/40/18 (this change the speedo ratio a bit so I prefer first choice) |
Drives: 2018 BRZ
I'm running 255/40/18 and with the stock suspension and they don't rub, But I'm not sure about being dropped an inch..
#5 | |
Drives: 2015 BRZ
Yes, i would recommend a 245/35 or 255/35 as your tire choices. I like keeping my tires close to OEM specs as well but its all just personal preference. |
| The Following User Says Thank You to Vital For This Useful Post: | calcal (07-03-2020) |
#6 | ||
Drives: 2018 BRZ PP (Modified)
What kind of tires are you running? I only had a few mm of clearance with the perch on 245/35s on stock suspension... Can't imagine 255/40 doesn't rub somewhere. Quote:
On coilovers 255/35 is ideal, 245/35 is fine though. |
| The Following User Says Thank You to Shizuka For This Useful Post: | calcal (07-03-2020) |
I actually is looking into 57DR 18x9.5 +38, same as your profile pic, are you running 255? does it feel sluggish for such wide tire in square setup? Given our car has only 205hp ... I may get tein CSG or flex Z coilover.
Nah on coilovers it doesn't feel sluggish at all, just make sure to get a proper alignment and dial in your negative camber. The car feels more planted than stock but in a good way.
| The Following User Says Thank You to Shizuka For This Useful Post: | calcal (07-14-2020) |
Drives: 2014 Subaru BRZ SC & 2018 Tacoma
I've been looking into this as well, since the wheels I'm getting are the exact same specs (18x9.5 +35mm). But I'll be on coilovers so I was debating going 265/35R18 as I have read on this forum they can be done. But I think I am going to go 255/35R18 all the way around instead, to minimize fitment issues.
Following this thread to see what others have success with! |
| Tire Fitment 18x9.5+35 | Cojonudo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 03-25-2024 01:06 PM |
| Need help on tire fitment | white_frs_e46 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-03-2015 07:25 PM |
| Rim and Tire fitment XXR 530 | zuurdeegfrs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 03-19-2015 10:17 PM |
| Need help on tire fitment, Please! | Rbmonroe | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-20-2014 01:52 PM |
| Tire fitment help!!!! PHOTOS! | FRSEVO | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 10-04-2013 07:48 PM |
