Old 06-21-2020, 11:21 AM   #1
golemslord
Drives: 2014 White FRS
Best tire fitment 18 x 9.5 +35
Hello,
Just wondering what might be the best fitment to fill in the wheel gap with TRD springs (1" drop) and 18x9.5+35 wheels.
Currently on 245/35/18 tires but wheel gap seems little big and tires little stretched
The current front setup has around half a finger gap before rubbing the suspension
Would a 255/35/18 rub? Or a 245/40/18 do the trick? Or 235/40/18?...
Not in a rush for tires, just getting advice for when my current tires need replacement
Thank you
golemslord is offline   Reply With Quote
Old 06-21-2020, 11:57 AM   #2
Vital
Drives: 2015 BRZ
Originally Posted by golemslord View Post
Hello,
Thank you
Unfortunately you have already maximized your setup without switching to coilovers. You will not be able to run 255/35 up front you should be able to in the rear, but i do not recommend using a staggered setup. A 245/40/18 is just a taller tire size than what you already have there would be no benefit to switching to that size. If you want to run wider tires you will need to upgrade to coilovers...
Old 06-28-2020, 04:06 PM   #3
calcal
Drives: 2019 Toyota 86 TRD SE
side question on this, I now may consider the same 9.5" width (57DR 18x9.5 +38) as this gives more concave looks. I will run with tein flex Z.
245 is consider stretched already for 9.5"? Any negative for this?
I plan to run 245/35/18 or 245/40/18 (this change the speedo ratio a bit so I prefer first choice)
calcal is offline   Reply With Quote
Old 06-28-2020, 05:30 PM   #4
MICHAEL450f
Drives: 2018 BRZ
I'm running 255/40/18 and with the stock suspension and they don't rub, But I'm not sure about being dropped an inch..
MICHAEL450f is offline   Reply With Quote
Old 07-01-2020, 09:27 AM   #5
Vital
Drives: 2015 BRZ
I dont think 245 is going to be super stretched. You can safely run 245/35/18 on that size wheel. Different tire manufacturers have variances and tolerances in sizes so they can be more wide or narrow when comparing two of the same sizes from different manufacturers. If you dont feel comfortable with a 245 you can even fit a 255 if you like with coilovers that wont be an issue.
Yes, i would recommend a 245/35 or 255/35 as your tire choices. I like keeping my tires close to OEM specs as well but its all just personal preference.
The Following User Says Thank You to Vital For This Useful Post:
calcal (07-03-2020)
Old 07-01-2020, 03:02 PM   #6
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
What kind of tires are you running? I only had a few mm of clearance with the perch on 245/35s on stock suspension... Can't imagine 255/40 doesn't rub somewhere.
On coilovers 255/35 is ideal, 245/35 is fine though.
Shizuka is offline   Reply With Quote
The Following User Says Thank You to Shizuka For This Useful Post:
calcal (07-03-2020)
Old 07-03-2020, 05:42 AM   #7
calcal
I actually is looking into 57DR 18x9.5 +38, same as your profile pic, are you running 255? does it feel sluggish for such wide tire in square setup? Given our car has only 205hp ... I may get tein CSG or flex Z coilover.
Old 07-10-2020, 09:26 PM   #8
Shizuka
Shizuka's Avatar
Nah on coilovers it doesn't feel sluggish at all, just make sure to get a proper alignment and dial in your negative camber. The car feels more planted than stock but in a good way.
calcal (07-14-2020)
Old 07-15-2020, 11:01 AM   #9
ArrrBussiere
ArrrBussiere's Avatar
Drives: 2014 Subaru BRZ SC & 2018 Tacoma
I've been looking into this as well, since the wheels I'm getting are the exact same specs (18x9.5 +35mm). But I'll be on coilovers so I was debating going 265/35R18 as I have read on this forum they can be done. But I think I am going to go 255/35R18 all the way around instead, to minimize fitment issues.
Following this thread to see what others have success with!
ArrrBussiere is offline   Reply With Quote
Tire Fitment 18x9.5+35 Cojonudo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 03-25-2024 01:06 PM
Need help on tire fitment white_frs_e46 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-03-2015 07:25 PM
Rim and Tire fitment XXR 530 zuurdeegfrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-19-2015 10:17 PM
Need help on tire fitment, Please! Rbmonroe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-20-2014 01:52 PM
Tire fitment help!!!! PHOTOS! FRSEVO Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 10-04-2013 07:48 PM
