Old 06-05-2020, 07:56 PM   #1
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Loose axle
I took the axle shafts out to check and re-lube the joints. They needed it and that all went well. When I reinstalled them I noticed where the inner joint seats in the diff has much more play than i recall when I removed it. I can only slide it outward a little before it stops. To go any farther it would have to pry it. I doubt it would leak since the seal is going to do its job anyway. This just seems odd. Any thoughts?
https://drive.google.com/file/d/1xuo...ew?usp=sharing
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Loose Cable Verb Engine, Exhaust, Transmission 8 02-14-2018 06:27 AM
Car feels loose Riftur Off-Topic Lounge [WARNING: NO POLITICS] 233 02-06-2018 09:27 AM
Help with loose wiring Terran Electronics | Audio | NAV | Infotainment 13 10-13-2016 04:07 PM
Gas pedal loose Enraged21 Issues | Warranty | Recalls / TSB 7 10-18-2013 02:18 PM
hood loose? boricua FR-S Issues | Warranty | Recalls / TSB 3 09-10-2013 09:29 PM
