Old 02-12-2018, 05:02 PM   #1
Verb
Drives: '17 BRZ and '15 Forester XT
Loose Cable
Hi Fellow BRZ/FRS drivers!
When changing my oil, I noticed a loose cable coming off the positive terminal of the battery. My BRZ is running fine and there are no warning lights on the dash. Any idea what that cable goes to and if this is an urgent repair?
Two photos of the loose cable below:
*Edit: Links to images as I think my newbie status is preventing me from embedding them:
Pic 1
Pic 2
Verb is offline   Reply With Quote
Old 02-12-2018, 07:24 PM   #2
humfrz
Pic 1
Pic 2
Hello Verb, and welcome to our fine forum .......
From your pictures, I can't identify the cable you are referring to .....??
Maybe if you describe the cable or point to it, I could help you.
Maybe others, with better eyes, will come along to help you out ......
humfrz
Old 02-12-2018, 07:27 PM   #3
toyubie
Drives: none
Same as humfrz, I don't see anything jumping out at me. Maybe you're talking about the ground to the tranny? But it looks bolted. Not sure.
toyubie is offline   Reply With Quote
Old 02-12-2018, 07:39 PM   #4
Appears to be a ground. Mine is bolted to the bell housing.
Let me dig deeper.
You can't upload the pics because the size is two large
Old 02-12-2018, 07:41 PM   #5
Ya that looked bolted to me as well until I saw how low it is. Should be much higher.
Old 02-12-2018, 07:44 PM   #6
Verb
Let me dig deeper.
Thanks for greetings and thanks for the edit above to highlight the loose cable. Appreciate the assist!
It sounds like it's a loose ground wire then?
Old 02-12-2018, 08:01 PM   #7
See that bolt just at the top of the yellow circle on yours? That is the same bolt that is underneath mine in my pic. There should be a hole about where mine is placed but the view is blocked in your pics.
Old 02-13-2018, 09:27 PM   #8
humfrz
Pic 1
Pic 2
Well, that threw me off ...... for a cable coming off the positive side of the battery going to ground .....
humfrz
Old 02-14-2018, 06:27 AM   #9
humfrz
It isn't coming off the battery at all. It comes down by the block.Nowhere near the battery.
Help with loose wiring Terran Electronics | Audio | NAV | Infotainment 13 10-13-2016 04:07 PM
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
Loose A-pillar ryoma Cosmetic Modification (Interior/Exterior/Lighting) 2 07-15-2015 05:00 PM
What to do with loose change robwbright Cosmetic Modification (Interior/Exterior/Lighting) 35 04-10-2014 01:46 PM
Gas pedal loose Enraged21 Issues | Warranty | Recalls / TSB 7 10-18-2013 02:18 PM
