Old 10-18-2013, 08:55 AM   #1
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
Gas pedal loose
I tried searching but could not find it.
I recently took a road trip to Miami and this is how I noticed the issue. A few times I was driving with the accelerator pressed all the way down. And while it is pressed I can feel the gas pedal move left and right.
I'm pretty sure this can't be a safe thing. Or am I just worrying for no reason?
Enraged21 is offline   Reply With Quote
Old 10-18-2013, 08:59 AM   #2
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Is it just the pad on the... I don't know the exact term, but the metal rod/arm the pedal pad is attached to? Or is it the whole arm?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-18-2013, 10:16 AM   #3
Enraged21
#RememberTheBuster
Enraged21's Avatar
Feels like the entire arm. I'll try to confirm later once I get off work.
Old 10-18-2013, 11:17 AM   #4
strat61caster
strat61caster's Avatar
It has play in it, most gas pedals do, 99% sure this is how it is. I would describe mine the same way.
ineedyourdiddly
Old 10-18-2013, 12:39 PM   #5
Enraged21
#RememberTheBuster
Enraged21's Avatar
Every other car I've driven I have never noticed it. But most of them were autos.
Old 10-18-2013, 12:51 PM   #6
Anthony
Weight Nazi
Anthony's Avatar
If it's just the pad on the arm, no big deal. And if it's just regular play, no big deal. But it's strange that you're just now noticing it. I know my other car's pedal has some play in it. Like if you're coasting down the road and release all pressure from the pedal, you can wiggle it back and fourth and the whole thing will move side-to-side.
Old 10-18-2013, 02:04 PM   #7
strat61caster
Mine isn't the pad, it's the whole arm, same with every other car I've had time to inspect (which admittedly isn't many).
ineedyourdiddly
Old 10-18-2013, 02:18 PM   #8
Anthony
Weight Nazi
Anthony's Avatar
Yeah, it's the whole pedal on mine too. Didn't realize I didn't specify that.
Is anyone else's dead pedal loose/making noise? KevinR Issues | Warranty | Recalls / TSB 41 01-16-2017 12:33 PM
hood loose? boricua FR-S Issues | Warranty | Recalls / TSB 3 09-10-2013 09:29 PM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 01:16 PM
Loose Glove Box Spd229 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-06-2012 01:53 PM
Loose Floor Mats mact Issues | Warranty | Recalls / TSB 0 09-14-2012 11:53 PM
