Old 05-19-2020, 11:45 PM   #1
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Harbor Freight Recalls Jack Stands That Could Suddenly Collapse
Just a PSA!.. Not sure if this has been posted. If so, please disregard....
el-guapin is offline   Reply With Quote
The Following 5 Users Say Thank You to el-guapin For This Useful Post:
Pat (05-20-2020), soundman98 (05-20-2020), Spuds (05-20-2020), squall leonhart (05-20-2020), wbradley (05-20-2020)
Old 05-20-2020, 02:17 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
I never leave things to a single point of failure. I always put the jack just touching next to them, as well as putting a wheel under the frame next to where I'm working. Would suck to scratch a wheel, but I'd still be able to scream for help between the crying.
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
alphasaur (05-20-2020), bfrank1972 (05-20-2020), NoHaveMSG (05-20-2020), Yoshoobaroo (05-22-2020)
Old 05-20-2020, 07:05 AM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This right here. I always leave a wheel or ramp under each side skirt.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
soundman98 (05-21-2020)
Old 05-20-2020, 08:26 AM   #4
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Wow, I have those exact jack stands in the picture in the link.
Old 05-20-2020, 08:47 AM   #5
Anybody that ever used a stock bumper jack is probably well in the habit of placing a wheel under the car even if just changing a tire!
IceFyre13th (05-21-2020), Irace86.2.0 (05-21-2020), soundman98 (05-21-2020)
Old 05-20-2020, 08:57 AM   #6
squall leonhart
kuro kitsune
Drives: 2002 Toyota Celica GT-S
Thanks...I'll have to double check the part number when I get home...but pretty sure I have these. Fortunately they (nor the Craftsman pair) did not fall when I used them while installing the TRD exhaust a couple weeks ago.
'02 Celica GT-S, '88 Celica All-Trac
'13 Scion FR-S (sold)
squall leonhart is offline   Reply With Quote
The Following User Says Thank You to squall leonhart For This Useful Post:
Old 05-20-2020, 10:27 AM   #7
p1l0t
p1l0t's Avatar
I usually leave the jack in place too if I can as a backup (after transferring weight to the jackstands). These look like every jackstand ever, however. I wonder if other retails are going to start doing recalls too because they are all made by the same factory...
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
DarkSunrise (05-20-2020), soundman98 (05-21-2020)
Old 05-20-2020, 10:43 AM   #8
DarkSunrise
DarkSunrise's Avatar
Just a heads-up - the red Pittsburgh jack stands in the picture look like exactly the same casting as a set of Sears/Craftsmen jack stands I have. Same 3 ton weight rating as well.
Luckily I only use these as backup jacks. I would bet more recalls are forthcoming.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
p1l0t (05-20-2020)
Old 05-20-2020, 11:33 AM   #9
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Went to return the ones I had. Got $20 gift card. Could have sworn I paid more than that but oh well. The store I went to (the only one in the area) was all out of jack stands
Old 05-20-2020, 11:58 AM   #10
p1l0t
p1l0t's Avatar
Because people are all stocking up jackstands like toilet paper during the crisis LMAO
el-guapin (05-20-2020)
Old 05-20-2020, 12:09 PM   #11
ls1ac
ls1ac's Avatar
Got to love bumper jacks. That was even a new one that went into a slot in the bumper, the old ones just hooked under the edge.
Old 05-20-2020, 12:12 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Same here, anytime I have to do work under the car a wheel goes under it too. Which is good because all 4 stands I was using fall under the recall. When I did my clutch and subframe I had the whole car as high as it would go on those stands.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 05-20-2020, 12:17 PM   #13
wbradley
Sarcastic SOB
wbradley's Avatar
They should all go back to China like all the millions of faulty N95 masks that they shipped to Canada.
China has definitely cemented it's place making crap now.
Old 05-20-2020, 01:11 PM   #14
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Lol!.. Must be.. Anywho, I order a set online. No rush. Used a 20% off code that basically took care of shipping.
The Following User Says Thank You to el-guapin For This Useful Post:
p1l0t (05-20-2020)
Harbor Freight - 3 Ton Low Profile Jack SmartedPanda DIY (Do-It-Yourself) Guides 41 01-16-2018 11:15 PM
Harbor Freight Jacks White64Goat Other Vehicles & General Automotive Discussions 28 12-27-2014 07:16 PM
Harbor Freight Low Profile Jack on sale $139 DarrenDriven Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-06-2014 06:18 PM
$10 Harbor Freight Catch Can ML Engine, Exhaust, Transmission 58 09-24-2013 01:31 PM
Aluminum 1.5 Ton Racing Jack on sale at Harbor Freight Foobar Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-22-2012 01:42 PM
