Old 04-30-2020, 08:00 PM   #1
mamamiaellis
Drives: brz
Steering clunk/pop
Hi everyone i was wondering if anyone could help me out.
Does anyone know what sound this is?
Im running aftermarket coils.
But i didnt have this problem anout a month ago .
Its during low speed.
The video is when the car is raised.
Thanks in advance
mamamiaellis is offline   Reply With Quote
Old 04-30-2020, 09:47 PM   #2
norcalpb
norcalpb's Avatar
Can you get a video of the spring doing the same kinda wheel turning?
Old 05-01-2020, 12:26 AM   #3
mamamiaellis
Drives: brz
The spring doesnt move. Or pop from what i can see.
All my bushings look fine.
Has anyone had any steering column noise?
The only thing i could think of actually making noise is the spring itself, swaybar/endlink, bearings, busbings, or steering rack/axle/cv.
Old 05-01-2020, 03:06 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, not the case of EPS motor coupler fix by chance? I don't recall vids of what noises were be in case for that failure though, and it was more of called "rattle" then such clunking .. probably would have asked someone else to turn wheels multiple times, while one listens from below of car to try locate noise source more exact direction.
Old 05-01-2020, 07:23 AM   #5
Halo_2
Drives: 2014 MY15 86 GTS
I know I've had my electronic steering motor replaced under warranty.
Halo_2 is offline   Reply With Quote
Old 05-01-2020, 08:31 AM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That doesn’t sound like the EPS coupling. The EPS coupling also didn’t make noise unless you have quick load reversal, not smooth inputs like this. The EPS clunk is most easily replicated driving straight on a dirt or gravel road.
Old 05-01-2020, 08:32 AM   #7
Yoshoobaroo
TRACKBREAD
Steering clunk/pop
Stock top hats?
You could try the screwdriver stethoscope trick to better pinpoint the location. I’d start at the top of the spring perch and top hat bearing.
Old 05-01-2020, 12:23 PM   #8
mamamiaellis
Drives: brz
So i have camber plates.
I didnt have this issue about a month ago.
Old 05-04-2020, 09:03 PM   #9
mamamiaellis
Drives: brz
Solved
Old 05-04-2020, 09:36 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Nice to hear. It would be beneficial though to tell others what exact problem was.
Old 05-05-2020, 05:53 PM   #11
mamamiaellis
Drives: brz
Sorry about that.
So i took it to a mechanic after weeks of being unable to self diagnose.
the souund is coming from the steering column itself past the steering rack/pinion towards the steering wheel.
suspension, steering rack, axles/joints are all clear.
Old 05-05-2020, 06:37 PM   #12
norcalpb
norcalpb's Avatar
Originally Posted by mamamiaellis View Post
Sorry about that.
Is it the U joint underneath the driver side kick panel?
Old 06-09-2024, 08:19 PM   #13
SmartalecBRZ
Drives: World Rally Blue Subaru BRZ
I am now having this same exact issue tried self diaging and can’t figure it out.
I’ve eliminated everything from the steering rack down being the culprit. I have even twisted the steering shaft coming up above the rack on a lift and the noise is Defintly coming from inside the cabin. It is not my eps at least doesn’t match any of the noises. It only clunks when gently shifting the steering wheel left and right. For the love of this community! Please bestow upon me the knowledge you have on solving this issue it is driving me crazy!
SmartalecBRZ is offline   Reply With Quote
Old 06-04-2026, 02:01 PM   #14
Jozy
Jozy's Avatar
Drives: 2015 Subaru Brz Limited
Question Help with Steering Clunk
This is the closest thread to an issue I'm experiencing, please help!!
I have a clunk coming from the steering wheel only when at dead center and moving left to right. Once past dead center I don't feel it. I'll list the parts I replaced below, though on my last work doing my tie rods. I grabbed t he steering shaft right at the U joint twisted left and right and I could replicate the sound. It can't be EPS because I replaced x2 this last time I replaced with a Hyundai Rubber one and cut the nips of so it would sit flush. (When I replaced the oem coupler the 2nd time it was still in tact.)
If it's the U Joint what are my options as far as replacement or upgrade?
I found Perrin sells a damper lockdown but does not fit our platform.
Any insight or help is greatly appreciated, I'm going mad trying to fix this noise!!
Parts Checked / Replaced:
Inner Tie Rods (GKTech)
Outer Rods (Moog)
Control Arm Bushings (Whiteline)
Perrin PolyUrethane Endlinks (One bushing was shot perrin sent me another and replaced)
Perrin Steering Rack Lock Downs with STI Bolts (Retorqued)
EPS Coupler with Hyundai Rubber Version (Nips Snipped)
Stock Sway bar replaced bushings with (Whiteline)
Struts from 2017 still solid
Jozy is offline   Reply With Quote
18 tS Pop/Clunk J1Avs Issues | Warranty | Recalls / TSB 20 04-01-2019 08:58 PM
2018 tS steering clunk Brz_racer Issues | Warranty | Recalls / TSB 18 12-10-2018 01:05 PM
Clunk noise when turning steering wheel to right noonedoesnt Issues | Warranty | Recalls / TSB 15 07-03-2018 09:14 PM
Thrust/pillowball mount bearing clunk while steering VacantSky Issues | Warranty | Recalls / TSB 14 06-04-2015 12:43 PM
Steering clunk over rough roads 73TORANA! Issues | Warranty | Recalls / TSB 39 12-05-2014 07:52 PM
