Drives: Subaru BRZ
2018 tS steering clunk
So I just got a 2018 tS and it has 1100 miles on it and the steering wheel is making a "clunk" when I turn the wheel at slow speeds. I can also recreate the issue sitting still and turning the wheel. If i turn the wheel to the right all the way to the stop, as soon as I turn it back to the left it makes the noise. When I'm pulling out of a driveway making a right turn it also makes the noise. I can feel it slightly in the steering wheel as well when it happens. Anyone else experienced this issue? And if so what was the fix?
No, but, if my car were new, I'd take it back to the dealer and ask them to sort it out and fix it.
humfrz |
#3 | ||
Had this exact same issue just last week and it's quite possible a wheel had a loose lug or two. Once everything was removed and re-torqued the issue disappeared.
Instagram: @spike.grc
Steve Bodalenko
Drives: Toyota 86 GTS
Why would anyone with a new car under warranty bother posting here in an attempt to find what was wrong with their virtually new car? Toyota/Subaru don’t give you a warranty for free or because they think you’re a great guy. It’s factored in to the price you paid for your car so use it at every op you get so you get the value out of it Anything to do with steering is a MUST return to dealer ASAP situation.
#5 | |
I reckon he just wants some input from the forum to possibly gain some background information before taking his car into the dealer . ![]() ![]() humfrz |
#6 | |
Drives: BRZ DGM Limited
Ya if you go to the dealer without a clue as to what it could be, they will F up your car. Just my opinion. |
Drives: Subaru BRZ
Well I'm taking it in Wednesday, when I go in I'll ask them that even if they are unable to find anything obvious, just check all the bolts and nuts and any other fastener that has to do with the steering or suspension. Almost guaranteed they will find something loose and not properly torqued. Was just looking for some input as I didn't want to walk in there cross-eyed with my **** in my hand.
Steve Bodalenko
Who here would really have a clue about a mysterious noise in the steering? Could be one of a hundred things. You just take the car straight back and say “Fix it!” You don’t need to know what’s wrong with it before you get it there. Not your responsibility. You only want to know what the did to fix it, why it needed fixing, and the likelihood of it happening again. So long as you get a copy of the service report to keep in your service book who cares. You worry about things tha go bang or squeal once you mod it or it’s out of warranty.
Drives: FRS 2013
#10 |
Mentat
Drives: 2013 Scion FRS 6MT
I worked at Toyota and we were never be able to find the cause of the clunk. 5 years down the road and the car is still fine. It just clunk from time to time.
#11 |
Drives: 2013 FR-S Series 10
I'm betting it disappears by the time you get to the dealer, as things like this usually do. I had a nice creak in my steering when parking for 2 weeks. Took it to a Subaru shop around here and it disappeared and never returned. Maybe just getting it on the lift fixed it.
#12 |
The Fail Boat
Drives: CWP S.B.
Grab a soft rubber mallet and jack the car up & start banging.
take it to dealer thou |
#13 | |
It had a heavy metal clunk/creak somewhere in the suspension. I asked Bubba how to fix it and he told me to spray the undercarriage and suspension with kerosene. I soaked (sprayed) about 2 gallons of kerosene all under that truck Bubba was wrong it still creaked loudly .. ![]() humfrz |
#14 | |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
I bet it disappears too. while my '13 never exhibited such a sound within 60 k miles, the steering clunk sound i started noticing in my '16 a few weeks ago has now disappeared.. though now that i think about it, i do have lowering springs whereas i kept the stock ride height on the first frs..not sure if it could be related to that
| Clunk noise when turning steering wheel to right | noonedoesnt | Issues | Warranty | Recalls / TSB | 15 | 07-03-2018 09:14 PM |
| Thrust/pillowball mount bearing clunk while steering | VacantSky | Issues | Warranty | Recalls / TSB | 14 | 06-04-2015 12:43 PM |
| Steering clunk over rough roads | 73TORANA! | Issues | Warranty | Recalls / TSB | 39 | 12-05-2014 07:52 PM |
| Whiteline Clunk fix | trippinbillies40 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-26-2013 05:44 PM |
| E-Brake clunk? | topazsparrow | Issues | Warranty | Recalls / TSB | 10 | 07-08-2013 11:23 PM |
