Old 04-19-2020, 05:07 PM   #1
Infinity
Drives: 2016 Scion FR-S
Does .1mm matter for hub centric rings? 65.1mm to 56.1mm vs 65mm to 56.1mm
I am looking to get some hub centric rings for my new set of wheels. The size I need is 65mm to 56.1mm, which is apparently pretty rare. The wheels are bronze, so I kind of don't want silver hub rings because I think it would look weird. This REALLY limits my choices lol.
I found these rings on ebay: https://www.ebay.com/itm/Set-4x-Spig...-/292847184884
They are 65.1mm to 56.1mm. My question is, will that .1mm make enough difference that they won't fit?
Infinity is offline   Reply With Quote
Old 04-19-2020, 05:09 PM   #2
vladniko86
vladniko86's Avatar
Drives: FRS
It's .1mm, if anything take a hammer to it
vladniko86 is offline   Reply With Quote
Old 04-20-2020, 03:57 AM   #3
86MLR
86MLR's Avatar
Use a fine file or dremel if required on the ring if you need clearance.
Please don't hammer it on or in.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 04-20-2020, 03:58 AM   #4
vladniko86
vladniko86's Avatar
Drives: FRS
it's metal it'll be fine
Old 04-20-2020, 06:08 AM   #5
86MLR
86MLR's Avatar
Until you need to remove it, or put on a spare, especially if it is on the hub, and your trying to fit a spare.
Hammering it to make it fit is lazy and shows poor mechanical aptitude.
Old 04-20-2020, 06:39 AM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Or - hear me out on this - spend a bit more on the proper rings. Saving 20 bucks isn’t worth this headache.
Old 04-20-2020, 06:55 AM   #7
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
If you can actually see the hub rings when the wheels are on the car something is very wrong.
Old 04-20-2020, 09:47 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
I'd very much wish to see hubrings, if they would be of wished size while being made in this form.
Old 04-20-2020, 09:56 AM   #9
Icecreamtruk
Drives: Track preped NA FRS
Or, hear me out here, dont use something that is not necessary? You dont "need" hub centric rings, nobody does, conical lugnuts (which 100% of the aftermarket wheels use) seat the wheels properly.
Old 04-20-2020, 10:24 AM   #10
Yoshoobaroo
TRACKBREAD
Not necessarily true, the stud holes in the hub aren’t nearly as accurately located as the hubcentric surface. It depends on how tactile you are, but I can absolutely feel the difference between rings and no rings, even with conical lugs torqued in a proper pattern. Lugcentric might be good enough for a 5000lb pickup truck, but on these cars it is noticeable. It also depends on the tolerance stack ups on your particular car. Maybe you got lucky and got hubs with stud holes located very close to nominal position, but more than likely you won’t get that lucky on all 4 of them. It will be worse on some cars than others, but the hub rings take that variable out.
If it wasn’t necessary for the wheels to be hubcentric, trust me, OEMs would not bother with it.
Old 04-20-2020, 11:26 AM   #11
Infinity
My understanding of how the hub rings fit on the wheel must not be right. I already ordered these ebay ones, they were only like $8. I will test fit them and see how they fit and then go from there.
Old 04-20-2020, 11:44 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Not "needed", true. Lugnuts tightened in right order should center wheel well. They make easier installation though (especially on bmw-ish like lug studs for mounting instead of studs and lug nuts), and net some piece of mind for relatively low cost, waay less then that of some aftermarket lugnuts. There can be lot of mods/parts for car with higher cost and even less function (have everybody already installed TRD fuel cap? ). Those who wish, can save slightly $ getting by without, those that wish them won't go bankrupt either.
Old 04-20-2020, 11:55 AM   #13
Tokay444
Anti stance.
Tokay444's Avatar
.1mm of interference is .1mm of interference. That shit ain't going on, and dremeling away material will just negate the entire purpose of a hubcentric ring.
Old 04-20-2020, 12:23 PM   #14
Yoshoobaroo
TRACKBREAD
Yea definitely. That's 4/1000", a pretty heavy press fit. And if they don't fit I agree, get different ones.
looking for a place that sells 56.1mm - 65mm hub centric rings Brinks Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-30-2016 12:43 PM
WTB: 65mm to 56.1mm Hub Centric Rings alexvc Want-To-Buy Requests 1 01-24-2015 05:57 PM
WTB Hub centric rings 65mm-56.1 Brinks Want-To-Buy Requests 2 08-27-2014 10:11 PM
SSR Type C RS hub centric rings Justkiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-14-2013 08:34 PM
FS: Hub centric rings 63 > 56.1 mm JDMSushi Australia Classifieds 3 02-09-2013 08:52 PM
