Drives: 2013 Subaru BRZ
Advice on Exhaust system
Hello I currently have an MXP Comp RS Catback Exhaust along with JDL Catted Unequal Length Header installed. I’ve been told I need to replace the rear catalytic converter which I believe I can just buy a catted front pipe ? There’s plenty on the market but does anyone have any suggestions that would sound good with my current set up? Any advice is helpful, thank you !
#2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
Catalytic converter has gone bad and thrown out a CEL, was told this would solve it.
ProCrastinationConsultant
i would just use an o2 defouler and be done with it...
but i'm still burning whale oil for light, so i'm not the most eco-friendly person in the world.
| The Following User Says Thank You to soundman98 For This Useful Post: | HaXx (04-17-2020) |
pessimistic skeptic
If you are getting cat related CEL, that is most probably due to first cat on the header where oxygen sensors are located. Rear cat converter does not cause CEL unless it is clogged bad. Your CEL could be related to header or something else. I would double check that CEL before buying a front pipe.
| The Following User Says Thank You to mrg666 For This Useful Post: | NoHaveMSG (04-17-2020) |
Drives: Crapcan
Does your car have a tune? If no then an o2 spacer works sometimes.
If yes, then you need to disable cel p0420.
Was told specifically that it was the rear one, it has made a rattle noise in that specific location after installing the set up, mostly at idle. And no it has no tune although I’ve been considering putting a stage 2 tune with an OFT.
Drives: jrsc_brz
honestly you could just pick up an oem front pipe from someone for $50 if that. i think the general concensus is that any aftermarket front pipe makes your car sound like a tinny, rapsy garbage, rice rocket blowing kazoo, fart canning, teenage, plasti-dipping-your-oem-wheels, ok im done. i know there are exceptions, but dont sleep on the oem front pipe.
edit: oh ya, the cat in the front pipe is way after any 02 sensors like mr g said, so its probably an issue in the after market header's cat, not your front pipe cat
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
| 360 degree surround camera system advice? | rendyr | Electronics | Audio | NAV | Infotainment | 9 | 07-12-2020 01:40 PM |
| Advice needed! Integrate aftermarket features into OEM+ style control system | Arcadien Angel | Electronics | Audio | NAV | Infotainment | 9 | 10-30-2017 11:02 AM |
| Exhaust Advice. I want a loud exhaust system please help | Rambo2469 | Engine, Exhaust, Transmission | 28 | 04-21-2017 03:41 PM |
| Exhaust System Advice | NIKOLA | Engine, Exhaust, Transmission | 5 | 02-11-2014 07:59 PM |
| New Sub System.. What do you guys think? Advice? | Sinthra | Electronics | Audio | NAV | Infotainment | 12 | 12-20-2012 03:16 PM |
