Old 12-08-2012, 12:36 PM   #1
Sinthra
Sinthra's Avatar
Drives: Scion FR-S
New Sub System.. What do you guys think? Advice?
So I have a 2013 Scion FR-S and I recently purchased 2 12' Alpine 12D4 Type Rs and 2 MRP-M500-Alpine Monoblock 500 Watt RMS amps (one for each). Any Ideas on what type of enclosure I should do? Or where and what position to face them? and if anyone was curious about the headunit, I have this Pioneer AVH-P2400BT. I was planning on building a custom enclosure with some lights and all for the show part lol But I figured while I'm trying to find all the specifics of what I'm going to do I would post it here and see what you guys thought =) So any suggestions or advice would be awesome!
Sinthra is offline   Reply With Quote
Old 12-10-2012, 08:38 AM   #2
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
I installed my two 12" Alpine's that I've had since 2005. I wound up creating two separate sealed enclosures and used the spare tire well for air space. The subs are inverted in the corners of the trunk.
It sounds really good but my amplifiers are way too big. You're in better shape with those Alpine amps.
Here's my build thread with a decent amount of pics: http://www.ft86club.com/forums/showthread.php?t=13425
Good luck with the build. Two 12s isn't truly necessary - may want to consider just one unless you've got time on your hands.
rmjjensen is offline   Reply With Quote
Old 12-12-2012, 09:18 AM   #3
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Can I just say over kill? I am using an older M500 model and I am running 2 JL 10's off it. They run extremely well.
Old 12-12-2012, 12:06 PM   #4
Sinthra
Sinthra's Avatar
Drives: Scion FR-S
Well I originally Bought them for my Jeep grand cherokee. But I never got them installed because a week after they came in the mail I bought the FR-S... So I figured I would just put them in there. But I'm probably just going to go with one 12. Or sell em for 2 8s.... I havent decided yet
Old 12-12-2012, 12:19 PM   #5
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
you can have 2 12" subs if you want, I am not against that. I meant that two amps of that caliber is overkill. you could run the two 12's off the one amp. (quite sure of it anyway)
I hear the FR-S rattles quite a bit with subs in the trunk tho. two very well powered 12" Alpine Type R's may really show that off.
Old 12-12-2012, 12:39 PM   #6
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I would just run 1, single 12 with 500w will be plenty.
JoeBoxer is offline   Reply With Quote
Old 12-12-2012, 05:57 PM   #7
SpeakBeck
Drives: SRT4
If they're the new Type R subs, they're actually 1000-1100watts RMS each. The old Type R's are 500watts RMS.
One MRP-M500 will not power two Alpine Type R 12's effectively. (old or new Type R's)
SpeakBeck is offline   Reply With Quote
Old 12-12-2012, 06:43 PM   #8
xjohnx
Grip>Slip
xjohnx's Avatar
hell, give me a nice 8" sub with a couple hundred watts and i'll be happy.
Old 12-13-2012, 08:20 AM   #9
rmjjensen
rmjjensen's Avatar
There's definitely rattle but honestly it's not that bad. The worst rattle I have is the rear view mirror. Every once in a while I have to take it completely off and snap it back in.
Old 12-13-2012, 03:26 PM   #10
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Interesting, thanks! Good to know.
Old 12-13-2012, 05:03 PM   #11
gmookher
I will be adding a prefab box for the trunk, 10" please. next spring when I am done with speed mods, a light stereo upgrade will be had
gmookher is offline   Reply With Quote
Old 12-18-2012, 02:04 PM   #12
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
The Toyota 86 comes with a full spare, no trunk liner, which just did not look the part, so I decided to fit Rockford Fosgate 8" sub built into the spare with 2 x Rockford Fosgate Punch subs hidden away behind the spare.
This build allowed me to keep full boot, with a cover for the sub if luggage required.
Sound is perfect, just that extra bass that is required.
Ryan86 is offline   Reply With Quote
Old 12-20-2012, 02:16 PM   #13
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Ive had 1 Alpine 12 R in my tC for the past 5 years or so and i can't imagine having more then that in a vehicle this size. JL makes a 8W3 that i plan on putting in the FR-S when it arrives, it should be more then enough, unless youre planning on annoying your neighbors or rattling your trunk to pieces.
Trashed675 is offline   Reply With Quote
12's, alpine, amp, audio, subs
Be Spoke system/ BRZ system navigation swap Mrqb22 Electronics | Audio | NAV | Infotainment 4 09-27-2012 05:48 PM
Need advice Ikmv Scion FR-S / Toyota 86 GT86 General Forum 7 08-23-2012 12:17 AM
Need advice.. Help.. tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 9 08-13-2012 08:57 PM
Need advice FRSMAK86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-06-2012 05:39 PM
FR-S or BRZ? Need some advice Davie Dynamite Scion FR-S / Toyota 86 GT86 General Forum 60 07-13-2012 10:47 PM
