Old 04-17-2020, 08:21 PM   #1
Enrique_13
Drives: 2013 Subaru BRZ
Advice on Exhaust system
Hello I currently have an MXP Comp RS Catback Exhaust along with JDL Catted Unequal Length Header installed. I’ve been told I need to replace the rear catalytic converter which I believe I can just buy a catted front pipe ? There’s plenty on the market but does anyone have any suggestions that would sound good with my current set up? Any advice is helpful, thank you !
Enrique_13 is offline   Reply With Quote
Old 04-17-2020, 08:31 PM   #2
Ashikabi
Ashikabi's Avatar
Why do you need to replace your cat? If it's for flow then yes you can just buy any catted front pipe. I imagine sound volume will increase a little but I don't see the sound changing much. If you go to a straight or resonated pipe your sound will likely change and volume will increase
Sent from my ONEPLUS A5010 using Tapatalk
Old 04-17-2020, 08:38 PM   #3
Enrique_13
Catalytic converter has gone bad and thrown out a CEL, was told this would solve it.
Old 04-17-2020, 08:46 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would just use an o2 defouler and be done with it...
but i'm still burning whale oil for light, so i'm not the most eco-friendly person in the world.
HaXx (04-17-2020)
Old 04-17-2020, 08:50 PM   #5
mrg666
pessimistic skeptic
mrg666's Avatar
If you are getting cat related CEL, that is most probably due to first cat on the header where oxygen sensors are located. Rear cat converter does not cause CEL unless it is clogged bad. Your CEL could be related to header or something else. I would double check that CEL before buying a front pipe.
The Following User Says Thank You to mrg666 For This Useful Post:
NoHaveMSG (04-17-2020)
Old 04-17-2020, 08:53 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Does your car have a tune? If no then an o2 spacer works sometimes.
If yes, then you need to disable cel p0420.
Old 04-17-2020, 09:30 PM   #7
Enrique_13
Was told specifically that it was the rear one, it has made a rattle noise in that specific location after installing the set up, mostly at idle. And no it has no tune although I’ve been considering putting a stage 2 tune with an OFT.
Old 04-17-2020, 10:20 PM   #8
HaXx
Drives: jrsc_brz
honestly you could just pick up an oem front pipe from someone for $50 if that. i think the general concensus is that any aftermarket front pipe makes your car sound like a tinny, rapsy garbage, rice rocket blowing kazoo, fart canning, teenage, plasti-dipping-your-oem-wheels, ok im done. i know there are exceptions, but dont sleep on the oem front pipe.
edit: oh ya, the cat in the front pipe is way after any 02 sensors like mr g said, so its probably an issue in the after market header's cat, not your front pipe cat
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
360 degree surround camera system advice? rendyr Electronics | Audio | NAV | Infotainment 9 07-12-2020 01:40 PM
Advice needed! Integrate aftermarket features into OEM+ style control system Arcadien Angel Electronics | Audio | NAV | Infotainment 9 10-30-2017 11:02 AM
Exhaust Advice. I want a loud exhaust system please help Rambo2469 Engine, Exhaust, Transmission 28 04-21-2017 03:41 PM
Exhaust System Advice NIKOLA Engine, Exhaust, Transmission 5 02-11-2014 07:59 PM
New Sub System.. What do you guys think? Advice? Sinthra Electronics | Audio | NAV | Infotainment 12 12-20-2012 03:16 PM
