Old 11-29-2018, 06:41 PM   #1
Kutchak
Turn Signal/Hazard Lights Issue
I've been experiencing some strange behavior from my turn signals. At first my left turn signal would stay solid. The bulb and the dash indicator were both solid. Also the right turn signal would work intermittently. After a while they all stopped working and now neither turn signals work. My hazard lights work when the car is off but they pretty much never work when the car is on. Sometimes they will work when the car is on, but only the right turn signal flashes, and it will only flash a couple times before it stops. Is this a relay issue? Thanks in advance.
Kutchak is offline   Reply With Quote
Old 11-29-2018, 07:47 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
sounds like a relay issue.. are you using any aftermarket head or taillights? have you tried replacing any of the bulbs?
HKz is offline   Reply With Quote
Old 11-29-2018, 08:12 PM   #3
humfrz
Welcome, Kutchak , to the forum-
I'd suggest you start by looking at the last things you did while messen with the lighting system -
Check the fuses, any bulbs you messed with, look for a blown fuse, a blown bulb or a not grounded bulb.
humfrz
Old 11-30-2018, 07:56 AM   #4
Kutchak
I haven't messed with the lighting system at all. I'm not sure if the previous owner installed aftermarket headlights or just blacked out the reflectors. Either way, it's not the fuse, I just tried it. I also don't see how it would be the bulb if the hazards work when the car is off. Also when I lock or unlock, the signals flash in addition to my parking lights working.
Therefore, I haven't tried replacing any bulbs.
Old 11-30-2018, 01:31 PM   #5
humfrz
hmmm.... did you check ALL the fuses associated with the lighting system?
There is one in the main fuse box under the hood and several in the fuse box under the dash.
humfrz
Old 11-30-2018, 06:30 PM   #6
maui86
Drives: 86
Something else to check - see if there's an aftermarket flasher relay under the dash
links to flasher relay diy here: https://www.ft86club.com/forums/showthread.php?t=49437
and here:
Pull it and see if it's a programmable one that can be reset (google whatever markings are on the relay - common ones are TapTurn and SmartTap)
If you have a friend with an 86 with working turn signals see if you can swap in their relay to test.
maui86 is offline   Reply With Quote
Old 12-03-2018, 08:51 AM   #7
Kutchak
Update
It was the relay. There was an after market relay in place by the previous owner. Switched it out and everything works as expected.
The Following User Says Thank You to Kutchak For This Useful Post:
bcj (12-03-2018)
Old 12-30-2021, 07:50 PM   #8
Frs2015california
Drives: Scion frs 2015 problem with my ligh
Where is located this relay because I'm having like the same problem but my dashboard and tail light and daytime are working but i can't turn off and my turn signal doesn't work at all
Frs2015california is offline   Reply With Quote
Old 01-02-2022, 09:25 PM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Under steering wheel
TOMs & turn signal issue Powered By Jay Cosmetic Modification (Interior/Exterior/Lighting) 19 01-14-2015 11:33 PM
OLM turn signal switchback issue Scavanger Scion FR-S / Toyota 86 GT86 General Forum 5 09-17-2014 11:42 AM
LED Turn Signal Issue FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 15 07-23-2013 12:47 PM
Turn signal issue Asphaltfrs1 Issues | Warranty | Recalls / TSB 3 06-21-2013 06:06 PM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
