Old 03-21-2020, 07:21 PM   #1
vleal12
LEAL GT
vleal12's Avatar
Drives: 2015 Toyota GT86
Stereo not working after changing battery
Help... I changed the battery and now the stereo doesn't work and the speakers are making a HUGE static sound that I had to take out the stereo fuse to stop the crazy noise...what can it be? I even took out the complete stereo (unplugged it) and put the fuse back and the very loud static noise is still there... took out the fuse again.
"If one day speed kills me, don't cry, because I was smiling." - Paul Walker
vleal12 is offline   Reply With Quote
Old 03-21-2020, 07:59 PM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Is your stereo system stock? Has it been modified in any way?
Have you tried disconnecting the power plug from the amp in the trunk and then trying the head unit again?
LimitedSlip is offline   Reply With Quote
Consensus on changing whole transmission versus changing solenoids dem00n Engine, Exhaust, Transmission 7 07-20-2016 03:50 AM
2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo brzsubarusti13 Audio/Visual, Electronics, Infotainment, NAV 11 02-27-2016 06:33 AM
Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo dssence Electronics | Audio | NAV | Infotainment 0 01-27-2015 06:43 PM
Window switches not working right after battery swap jonbonazza Issues | Warranty | Recalls / TSB 9 01-10-2014 02:50 PM
stereo and clock not working FRSGIRL❤ Issues | Warranty | Recalls / TSB 6 04-30-2013 11:45 AM
