Old 04-28-2013, 12:04 PM   #1
FRSGIRL❤
Blondes do it better!
FRSGIRL❤'s Avatar
Drives: 2013 Whiteout FRS
stereo and clock not working
stereo and clock not working. checked interior radio fuse which is not blown.
any other suggestions on what to check?
FRSGIRL❤ is offline   Reply With Quote
Old 04-28-2013, 12:07 PM   #2
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
Might seem like a smart ass response, but in all seriouness have you checked to make sure the stereo is turned on? If so take it to the dealership and make them fix it.
Chattanooga Scikotics MFIC
Red Robin Build
L3P47 is offline   Reply With Quote
Old 04-28-2013, 01:07 PM   #3
Dezoris
Dezoris's Avatar
Is it when the lights are on or off?
there is a fuse for interior trim illumination that is blown. look in the owners manual. its a fuse panel inside the car. i blew this one as well when installing my head unit.
Old 04-28-2013, 01:25 PM   #4
FRSGIRL❤
FRSGIRL❤'s Avatar
I actually looked into the wiring diagram manual online and found that dome fuse under the hood was blown.
no spare 20amps around so I'll grab one from the store, should fix my problem unless the illumination fuse is blown as well. I'll have a look into that.
thanks again!
Old 04-28-2013, 07:01 PM   #5
SilentAngel
Guest
Posts: n/a
Did u by chance check the fuses? I think the radio and clock are on the same fuse.
Edit: nvm missed the last post lol
Old 04-29-2013, 03:10 PM   #6
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
yeah they are on the same fuse. there should be a spare of each fuse in the box so you shouldn't need extras unless you already used the ones in there.
phanguy is offline   Reply With Quote
Old 04-30-2013, 11:45 AM   #7
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Better question - what has changed recently that would cause fuses to pop?
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
DIY-Changing Clock/HVAC LEDs on FR-S Lil Abner DIY (Do-It-Yourself) Guides 113 03-11-2022 01:40 PM
Replace clock with radar display? xjohnx Electronics | Audio | NAV | Infotainment 18 09-21-2014 01:23 PM
CLOCK QUESTION poudre BRZ First-Gen (2012+) — General Topics 16 07-02-2012 02:20 PM
Toyota digital clock hacks? slaxx Electronics | Audio | NAV | Infotainment 1 07-01-2012 12:39 PM
