Old 03-18-2020, 10:07 PM   #1
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Seat Bolt Trouble
Hello,
I need some help on getting my seat bolt out. The previous owner attempted to get it out but made it worse. There is an extractor stuck in there. Who knows what they did! Anyone have any tips or tricks or recommend a good race shop in Socal? Thanks
scion fr-s is offline   Reply With Quote
Old 03-18-2020, 10:26 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I hammered on a 7mm socket till it stuck to what was left of the bolt. Torched the bolt. Then it finally came out.
I burnt the carpet just a bit, so be careful!
I LIKE TIRES!
scion fr-s (03-18-2020)
Old 03-18-2020, 10:31 PM   #3
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Thanks, I will put some aluminum foil down just to be safe and then torch it.
Old 03-18-2020, 10:57 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
I would weld a socket to it.
scion fr-s (03-19-2020)
Old 03-18-2020, 11:13 PM   #5
new2subaru
Weight Weenie
Drives: 15 FR-S
Another option is to drill the heads off
https://www.ft86club.com/forums/show...7&postcount=22
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
scion fr-s (03-19-2020), Ultramaroon (03-19-2020)
Old 03-18-2020, 11:35 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
If you have a dremel and are really patient, you can grind off the head. The screw itself will easily back out.
I prefer nibbling at stuff with those cutoff wheels.
Leonardo (03-19-2020), scion fr-s (03-19-2020), soundman98 (03-19-2020)
Old 03-18-2020, 11:43 PM   #7
Ultramaroon
not playing cards
I started typing a sentence and took a break for dinner. I could see this working way better than grinding.
Old 03-19-2020, 12:23 AM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
This was very frustrating when it happened. When I finally got it out, I threaded a nut to the bottom of the bolt and then ground the round head to the shape of the nut. Then a socket fit over it. Swapped a front bolt that wasn't stripped to the back and used my new "custom" bolt in the front.
Still plenty of engagement threads holding the seat in. Safety first.
I LIKE TIRES!
Old 03-19-2020, 01:20 AM   #9
Ultramaroon
not playing cards
OMG! How in the world can you build such beautiful things and accept that abortion.
Don't make me drive down and fix it for you. I'm warning you, goddammit. I'll do it.
Leonardo (03-19-2020), soundman98 (03-19-2020)
Old 03-19-2020, 01:34 AM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Let's plan on that
My birthday? July 31st? I'll keep in touch...
I LIKE TIRES!
Old 03-19-2020, 01:44 AM   #11
Ultramaroon
not playing cards
Let's plan on that
Alright but I promise I'll give you shit about it until then.
maybe just a little.
Old 03-19-2020, 09:00 AM   #12
new2subaru
Weight Weenie
Drives: 15 FR-S
I did it on my own out of desperation and it worked like a charm. There's always a risk when mangling a bolt though. It doesn't matter what method is used.
The Following User Says Thank You to new2subaru For This Useful Post:
Old 03-19-2020, 12:07 PM   #13
HaXx
Drives: jrsc_brz
its an E10 socket for those wanting to prevent future trouble like this
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Opie (03-22-2020)
Old 03-19-2020, 01:13 PM   #14
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Some bolts are pre mangled. I swear 3 of mine on my drivers side has some sort of growths coming out of them that prevents the socket from seating flat. The passenger side was easy and 1 of the driver side was easy, but the last 3 are just being evil. I'm going to wait to it warms up and see if that helps anything.
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 02:06 PM
Need Help Unbolting The Seat Rail Bolt hooverbucs14 Scion FR-S / Toyota 86 GT86 General Forum 2 01-09-2015 11:59 AM
Seat rail bolt part number? nalc Cosmetic Modification (Interior/Exterior/Lighting) 5 12-05-2013 10:16 AM
Trouble Changing Oil, Rounded Bolt =( RiceCooker Mid-Atlantic 7 08-12-2013 08:55 AM
need help unbolt seat rail bolt chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 2 07-01-2013 10:06 AM
