Drives: 2016 Scion FR-S
3rd Brake Light Vibration TSB?
I have a 2016 FR-S and sometimes the 3rd brake light makes a very loud vibration noise. I searched on the forums and found that many other people had this issue in the past.
Apparently, at some point Subaru started making the bottom bottom piece of the 3rd brake light with a strip of foam along the edge to stop the vibration noise. From what I read, since my car is a 2016 it should have this strip of foam on the 3rd brake light but it does not. I checked the TSB thread here and I can not find it. Does anyone know the TSB number for the 3rd brake light vibration noise? It would be easiest if I can just go to the dealer with the TSB number and have them install the new piece. If there is no TSB or the TSB is only for Subaru or something, does anyone have the part number for the new 3rd brake light piece with the foam strip? |
TRACKBREAD
You can go to a craft store and buy a sheet of adhesive felt, it's literally a dollar:
https://www.michaels.com/creatology-...caAiQuEALw_wcB Cut the sheet into ~0.2" strips and adhere those to the brake light housing where it touches the base, but not too much such that it doesn't click in anymore. Should take care of the rattling. |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
Did not find this TSB for Toy/Sci vehicles. Found one under '14 Brz. Part number is 84701CA002VH.
Work Hard. Play Hard.
2016 Oceanic |
| The Following User Says Thank You to ActionMaxon For This Useful Post: | Infinity (03-19-2020) |
Okay. It seems Subaru must have issued a TSB but not Toyota. Not sure if I should try and fix it myself or buy this part now.
The new part just has a bit of fabric on it. Otherwise it's the same. You can fix it yourself for a fraction of the cost.
2016 Oceanic |
#7 | |
Drives: 2016 BRZ
(See attached) |
| DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video | continuecrushing | DIY (Do-It-Yourself) Guides | 44 | 11-23-2020 07:17 PM |
| 17+ Taillights, 4th Brake Light, Valenti Brake Light Harness, PPF & More | kashmir | Exterior Parts (Aero, Lighting, Etc.) | 7 | 12-11-2019 03:42 AM |
| DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) | BirdTRD | DIY (Do-It-Yourself) Guides | 17 | 11-06-2017 09:42 PM |
| New owner! Question about warranty and brake pedal vibration | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 12-10-2014 01:22 PM |
| For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! | Vicious LED | Exterior Parts (Aero, Lighting, Etc.) | 9 | 08-25-2013 08:26 PM |
