Old 03-17-2020, 01:46 PM   #1
Infinity
Drives: 2016 Scion FR-S
3rd Brake Light Vibration TSB?
I have a 2016 FR-S and sometimes the 3rd brake light makes a very loud vibration noise. I searched on the forums and found that many other people had this issue in the past.
Apparently, at some point Subaru started making the bottom bottom piece of the 3rd brake light with a strip of foam along the edge to stop the vibration noise. From what I read, since my car is a 2016 it should have this strip of foam on the 3rd brake light but it does not.
I checked the TSB thread here and I can not find it. Does anyone know the TSB number for the 3rd brake light vibration noise?
It would be easiest if I can just go to the dealer with the TSB number and have them install the new piece. If there is no TSB or the TSB is only for Subaru or something, does anyone have the part number for the new 3rd brake light piece with the foam strip?
Infinity is offline   Reply With Quote
Old 03-17-2020, 04:22 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You can go to a craft store and buy a sheet of adhesive felt, it's literally a dollar:
https://www.michaels.com/creatology-...caAiQuEALw_wcB
Cut the sheet into ~0.2" strips and adhere those to the brake light housing where it touches the base, but not too much such that it doesn't click in anymore. Should take care of the rattling.
Old 03-18-2020, 01:40 PM   #3
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Did not find this TSB for Toy/Sci vehicles. Found one under '14 Brz. Part number is 84701CA002VH.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following User Says Thank You to ActionMaxon For This Useful Post:
Infinity (03-19-2020)
Old 03-19-2020, 08:33 AM   #4
Joon525
Joon525's Avatar
Drives: 2016 BRZ
https://subaru.oemdtc.com/917/vibrat...014-subaru-brz
Joon525 is offline   Reply With Quote
The Following User Says Thank You to Joon525 For This Useful Post:
Old 03-19-2020, 01:07 PM   #5
Infinity
Okay. It seems Subaru must have issued a TSB but not Toyota. Not sure if I should try and fix it myself or buy this part now.
Old 03-19-2020, 02:18 PM   #6
ActionMaxon
The new part just has a bit of fabric on it. Otherwise it's the same. You can fix it yourself for a fraction of the cost.
2016 Oceanic
Old 03-19-2020, 05:23 PM   #7
Joon525
Joon525's Avatar
Drives: 2016 BRZ
You go on Amazon or your local store of choice to buy some foam tape and do this yourself.
(See attached)
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
17+ Taillights, 4th Brake Light, Valenti Brake Light Harness, PPF & More kashmir Exterior Parts (Aero, Lighting, Etc.) 7 12-11-2019 02:42 AM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
New owner! Question about warranty and brake pedal vibration BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 2 12-10-2014 12:22 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
