Drives: Subaru BRZ 2014
JRSC C38 High Intake Air Temps
I recently bought a used JRSC C38 kit and I'm running the stock size pulley (8psi with headers)
While datalogging I noticed intake air temps were shooting high on WOT runs. Intake air temps would go 20C+ (35F+) above ambient so at 25C (77F) ambient temp, the intake air temps would reach 45C (113F) and at 35C (95F) ambient temp, the intake air temps would reach 55C (131F) Are these temps normal to see on this setup? What could the problem be? Failed intercooler? Any input would be appreciated |
| The Following User Says Thank You to Nael For This Useful Post: | HachiRokuX (03-04-2020) |
Drives: brz 2017 hksv2
very normal
compression heats charge air A LOT without intercooler you would see even extremely higher values |
Pretty normal.
Duct your cooling stack for better results. |
| Does this look like an exhaust leak or normal discoloration from high temps? | kev0 | Engine, Exhaust, Transmission | 17 | 01-07-2020 03:48 PM |
| Unusually high oil temps? | mistople | Engine, Exhaust, Transmission | 20 | 04-25-2018 03:18 AM |
| Coolant Temps Running High | Dezoris | Tracking / Autocross / HPDE / Drifting | 43 | 09-29-2016 12:58 PM |
| Coolant Temps WAY TOO HIGH | itsjustdavep | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 45 | 08-25-2016 02:41 PM |
| ECU pulls timing at high oil temps? | brillo | Engine, Exhaust, Transmission | 24 | 03-31-2013 10:10 PM |
