Old 08-18-2016, 07:26 PM   #1
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
Coolant Temps WAY TOO HIGH
Hi. I know, use search, blah blah. Don't got time I'm on side of road.
Was driving tamely and my AC started blowing warm. I live in Orlando, and I'm chubby. My AC is ALWAYS on.
About 5 minutes ago my coolant temps shot up to 240 and my AC started blowing like an oven. I immediately pulled over and shit the car down and topped off my coolant.
Gave it a full chance to cool off. Started her back up but the temps are starting to climb again.
So, cracked radiator or something else?
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 08-18-2016, 07:29 PM   #2
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
no visible leaks?
shiumai is offline   Reply With Quote
Old 08-18-2016, 07:30 PM   #3
gramicci101
Off Topic
First: topped off your coolant with what exactly? Random coolant from Autozone, or vehicle-specific coolant from Toyota or Subaru?
Second: do your fans cycle?
Third: Does the water pump work?
Old 08-18-2016, 07:30 PM   #4
itsjustdavep
Sprayed all over the header. Up on hood. Fans.
Small puddle once I pulled over.
Old 08-18-2016, 07:31 PM   #5
itsjustdavep
Prestone 50/50. Been using it for two years already.
Fans are cycling.
Not sure how to make sure water pump is working.
Old 08-18-2016, 08:05 PM   #6
wbradley
Sarcastic SOB
wbradley's Avatar
Warranty
Old 08-18-2016, 08:06 PM   #7
itsjustdavep
Originally Posted by wbradley View Post
Warranty
Car is at 40k. And I was second owner
Old 08-18-2016, 08:06 PM   #8
itsjustdavep
Also could I possibly be looking at a thermostat problem? Perhaps it's not kicking.
Old 08-18-2016, 08:29 PM   #9
ryoma
ryoma's Avatar
try to find the source of that leak.
Old 08-18-2016, 08:33 PM   #10
itsjustdavep
Everything is still wet and it's dark. I'll have to check in the morning
Old 08-18-2016, 08:38 PM   #11
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
There's a reason we're supposed to use the ridiculously over priced OEM coolant. Generic off-the-shelf stuff like Prestone is liable to cause a problem.
If you crank the heat (no AC, full on heat on high) does that help your coolant temps? When you topped off the coolant, how low was it? What sprayed all over the place? Coolant? How hot did your oil temps get?
Old 08-18-2016, 08:41 PM   #12
itsjustdavep
Oil didn't pass 170 which I'm hoping is normal. Coolant went everywhere. I'll try the heat thing now and get back to you guys
Old 08-18-2016, 09:14 PM   #13
itsjustdavep
No luck. The heat on max and coolant started climbing past 215 while idling
Old 08-18-2016, 09:23 PM   #14
humfrz
The thermostat may be stuck closed .....if so replace.
To find the leak, I suggest you fill it up with "water" and find out where it's leaking. ...... drain water.
Fix leak.
Re-fill with the OEM blue stuff.
humfrz
Toyarzee (08-19-2016)
Coolant Temps Running High Dezoris Tracking / Autocross / HPDE / Drifting 43 09-29-2016 11:58 AM
High coolant temp at idle with A/C off extrashaky Issues | Warranty | Recalls / TSB 11 11-11-2014 04:50 PM
Anyone notice this car eats coolant at a high rate? Liquidsnake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 04-23-2013 04:25 PM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
ECU pulls timing at high oil temps? brillo Engine, Exhaust, Transmission 24 03-31-2013 09:10 PM
