Old 01-06-2020, 03:43 PM   #1
kev0
Drives: '14
Does this look like an exhaust leak or normal discoloration from high temps?
kev0 is offline   Reply With Quote
Old 01-06-2020, 05:56 PM   #2
humfrz
Exhaust leaks usually don't leave a smudge coating all over the exhaust.
Is that header OEM or aftermarket?
humfrz
Old 01-06-2020, 06:07 PM   #3
kev0
Drives: '14
humfrz
Hmm, ok. I thought when a exhaust leaks, it lets out soot and vapor and coats everything it gets in contact with.
It's a cheap aftermarket header.
Old 01-06-2020, 07:14 PM   #4
humfrz
Usually, an exhaust leak will only leave a smudge mark close to where it's leaking before it dissipates.
If your exhaust leak was bad enough to do what your picture shows, you would definitely hear and smell it.
So, what is your aftermarket header made out of?
If it doesn't make any noise and you can't smell exhaust, I wouldn't worry about the discoloration.
After all, we put up with rusty, cast iron exhaust manifolds for years -
humfrz
Carsnguitars (01-11-2020), kev0 (01-06-2020)
Old 01-06-2020, 10:16 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
From the looks of and from what you said, I say it just burn up the clear coat or what ever coating it had. If it was an exhaust leak you would have heard it.
Old 01-06-2020, 10:56 PM   #6
kev0
Drives: '14
Dang..I was hoping it would be an exhaust leak cause that would be easier than tearing my car apart trying to find the leak.
There's also this soot under the hood of my car, presumably from the 'exhaust' leak.
The Following User Says Thank You to kev0 For This Useful Post:
humfrz (01-06-2020)
Old 01-06-2020, 11:09 PM   #7
humfrz
That stuff on the hood looks like some fluid was slung up there by a pulley or a belt. Does the belt look/feel "wet" or does any pulley have a residue on it?
I suggest you clean it off the hood and see if it comes back.
As far as the dark header, I suggest you contact the manufacturer to see if they can give you any insight.
Again, do you know what that header is made of or was coated with?
humfrz
Ultramaroon (01-07-2020)
Old 01-06-2020, 11:13 PM   #8
humfrz
I'm going to ring up ol @Ultramaroon for ya, he is pretty good at figuring out stuff like this -
humfrz
kev0 (01-06-2020)
Old 01-06-2020, 11:18 PM   #9
kev0
Drives: '14
humfrz
Good point. Going to wipe it up and see if it comes back.
As for the header...manufacturers says T-304 Stainless Steel.
humfrz (01-07-2020)
Old 01-07-2020, 12:54 AM   #10
Stomachbuzz
Drives: 2013 FRS
My immediate first thought when seeing the header was something has been cooked onto it. An oily fluid dripped onto it while hot.
The picture of the underside of the hood was the absolute giveaway though.
Stomachbuzz is offline   Reply With Quote
Old 01-07-2020, 12:59 AM   #11
kev0
Drives: '14
Ahhh... absolute giveaway to what? Exhaust leak or oily fluid leaking?
Old 01-07-2020, 01:13 AM   #12
86TOYO2k17
Drives: 2017 toyota 86
Oily fluid. Is your SC losing a lot of oil?
From the looks if some oil is dripping onto the belt flinging it to the hood. And dripping all over header causing it to burn and discolor. From the amount it’s either been going on for s while or its a pretty bad leak.
Do you also have that black stuff to the left and right side of the serpentine belt?
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Stomachbuzz (01-07-2020)
Old 01-07-2020, 01:18 AM   #13
kev0
Drives: '14
Surprisingly not.. It's some sort of oil for sure but I don't think it's the SC gear oil. I think it's PCV blowby. I'm not sure how its getting into the SC unit itself and leaking.
I clearly do see a leak on the SC itself but it's just so weird how it's not SC oil.
Old 01-07-2020, 01:20 AM   #14
86TOYO2k17
Are you losing engine oil then?
No catch cans?
Unusually high oil temps? mistople Engine, Exhaust, Transmission 20 04-25-2018 02:18 AM
Coolant Temps Running High Dezoris Tracking / Autocross / HPDE / Drifting 43 09-29-2016 11:58 AM
Coolant Temps WAY TOO HIGH itsjustdavep Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 45 08-25-2016 01:41 PM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
ECU pulls timing at high oil temps? brillo Engine, Exhaust, Transmission 24 03-31-2013 09:10 PM
