Old 02-20-2020, 06:22 AM   #1
strapped
Changing Automatic Transmission Fluid
Hello guys! I recently did a motor swap on my 2013 FR-S & threw in a 2016 FA20 from a BRZ, the car is automatic. On the first start there was a loud squealing noise coming from the back of the motor (sounded like the accessory belt squeal). After a while I realized that I didn't add any ATF into the transmission so I got some of Toyota's WS ATF.. I did some research on the forums & they said to drain it, refill until its dripping out of the transmission which should have only taken 2.1 quarts.. Mine took about 4 quarts for anything to show up, is this normal after a motor swap since most of it came out with pulling the motor? Need someone to point me in the right direction as I'm not sure what to do about the whole situation & not trying to start it again in case it causes more damage to the transmission. Below is a video of what the car sounds like.
[ame="https://www.youtube.com/watch?v=B-xOuyHdSV4"]https://www.youtube.com/watch?v=B-xOuyHdSV4[/ame]
strapped is offline   Reply With Quote
Old 02-21-2020, 08:56 PM   #2
humfrz
Hello strapped and welcomed to our forum -
First off, I can't hear anything in your video except the exhaust sound.
So, you added 4 quarts to the transmission not knowing how much was in there? Therefore, you don't know how much oil is in the transmission at this time?
I'd suggest you research the maintenance manual (available here on the forum) about changing the AT fluid. Then check the DUI section for some hints.
humfrz
Old 02-21-2020, 09:07 PM   #3
86TOYO2k17
Drives: 2017 toyota 86
https://shop.ukrtrans.biz/wp-content...logs/A960E.pdf
Old 02-23-2020, 01:19 PM   #4
Stomachbuzz
Drives: 2013 FRS
It is likely 2.1 quarts in the transmission pan alone.
ATF fluid also sits in the torque converter, and ATF cooler & lines, if the car has one.
So a "drain & fill" is probably 2.1 quarts, but the complete capacity of the system is much more.
Stomachbuzz is offline   Reply With Quote
Automatic Transmission Fluid, is this what you use? qijian Engine, Exhaust, Transmission 2 11-30-2017 02:41 AM
Changing Differential and Transmission fluid Seabass47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-20-2017 01:21 AM
Changing Automatic Transmission Fluid euthqt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 06-01-2016 04:16 AM
AUTOMATIC TRANSMISSION FLUID? How many L ScionFR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-21-2015 01:43 AM
changing the transmission of an fr-s from automatic to manual. enjoi23 Engine, Exhaust, Transmission 55 08-23-2012 12:24 AM
