Old 02-06-2015, 07:06 AM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Exclamation AUTOMATIC TRANSMISSION FLUID? How many L
Hey guys how many liters does the AUTO frs transmission take? And when did you change it? I can't seem to find it anywhere & I don't think its 3-4L bc that's what the manual tranny takes so only if you definitely know of have an auto and have swapped your fluid please help me out!
Thanks
-mike.
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 02-06-2015, 10:49 AM   #2
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
check the service manual..
and i dont think its a simple drain and fill process like the manual, you need a machine to drain it if i recall correctly.
Old 02-06-2015, 05:48 PM   #3
ScionFR-S
ScionFR-S's Avatar
Yeah I would bring it to the mechanic to do , I'll have to see the manual
Old 02-20-2015, 07:36 PM   #4
ScionFR-S
ScionFR-S's Avatar
anyone change their oil yet if so what did you use !
Old 02-20-2015, 08:10 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Thanks
-mike.
The mechanic will know how much to use
Like 5 threads down
http://www.ft86club.com/forums/showthread.php?t=55315
Old 02-21-2015, 12:43 AM   #6
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Automatic (TX6A)
7.5L (7.9 US QT) ATF Type WS C0009-WSATF-12
Muaddib is offline   Reply With Quote
Automatic Transmission Fluid Cooler. ?? connor_lol Engine, Exhaust, Transmission 177 01-02-2023 09:02 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
6MT Transmission Fluid Recommendations Ferrari Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 97 04-30-2015 05:06 AM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
