Old 02-11-2020, 11:06 AM   #1
H_K
Drives: '13 Scion fr-s
Best/easiest way to get better light output?
I'm not satisfied with the light output of the OEM headlights at night time. They seem to barely light up the road ahead of me. I'm in a '13 FR-S. My goal is to have something brighter that can let me see more at night time.
I'm really not educated on lighting for this platform. What would be my options without replacing the entire assembly with something aftermarket?
Are there any brighter bulbs I can just swap out?
HID conversion kits don't seem very expensive. But I'd need to do some extra wiring, include a ballast, and there's quite a bit more involvement, correct?
I'm reading that a VLand/Morimoto swap although looks super cool doesn't really have great light output, so that would not accomplish my goal.
H_K is offline   Reply With Quote
Old 02-11-2020, 11:10 AM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Correct way is to open it up, retrofit in some morimoto projectors with HID. TRS is what I use, I believe they have a projector that fits into the OEM Stock Headlights without having to create an adapter plate/drilling.
If you stick brighter bulbs like HID into the stock halogen, it'll improve a little bit but it's not ideal.
Clueless
YamahaR86 is offline   Reply With Quote
Old 02-11-2020, 11:21 AM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
See below.
Originally Posted by HeresMyMind View Post
I installed STi-r clear lenses on the OEM projectors, new bulbs are on the way to replace the 4 year old faded d4s bulbs.
Doing this mod replaces the oem projector lenses which cause the cutoff to be foggy/blurry. This makes for a more crisp / blue cutoff. Because I am a retrofitter it only makes sense to do this! It also adds a bit more intensity in the center.
-B
The BRZ and HID model FRS/GT86 all use the sane projector commonly known as the RX350 projector
-B
EDIT: This is only if you already have HIDs. If not, then a projector retrofit would be needed, not just the lenses
BigTuna is offline   Reply With Quote
Old 02-11-2020, 12:10 PM   #4
H_K
Originally Posted by BigTuna View Post
See below.
I do not have HIDs.
Old 02-11-2020, 12:12 PM   #5
H_K
Are there any tutorials I can follow for retrofitting the morimoto projectors with HID? Or kits that you can recommend?
Old 02-11-2020, 12:23 PM   #6
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Since the lenses are a few years old, polishing up the outside surfaces may help a bit.
Old 02-11-2020, 12:39 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes! I polish mine once a year. I wet sand with 1500,2000,2500, then finish with Meguires plastic-x polish. It keeps them looking new.
OP, fog lights are a good way to add some light.
I LIKE TIRES!
Old 02-11-2020, 12:44 PM   #8
H_K
I've installed some fog lights already They're brighter than my headlights it seems.
The Following 2 Users Say Thank You to H_K For This Useful Post:
Busybee (02-11-2020), Leonardo (02-11-2020)
Old 02-11-2020, 07:56 PM   #9
HaXx
Drives: jrsc_brz
talk to heresmymind, he is our resident lighting guru
HaXx is offline   Reply With Quote
Old 02-11-2020, 09:29 PM   #10
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Not sure how easy it is but you could get BRZ hid lights.
Old 02-12-2020, 03:52 PM   #11
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
I believe these might just mount up to the OEM headlight's bracket without needing to cut or drill, I would email or call them to confirm:
https://www.theretrofitsource.com/mo...cion-gt86.html
I haven't messed with OEM projectors to tell, always made my own mounting plates/drilled if they didn't line up. Have to make sure you have a way to angle or adjust them when fabricating a mounting plate.
I've used FXR Projectors in motorcycles and currently in my car I have the H1 Mini in the Spec-D Headlights.
Remove headlights from car, bake open headlights in the oven or use a heatgun, split the lens/base and then you can remove the reflect/projector. I think there are a few guides on here where people opened them to paint the inside.
Clueless
Old 02-13-2020, 12:13 AM   #12
scotto79
Drives: 2016 Ablaze FRS
Are your headlights adjusted properly height wise?
scotto79 is offline   Reply With Quote
The Following User Says Thank You to scotto79 For This Useful Post:
Boomerang (02-13-2020)
Old 02-13-2020, 02:16 AM   #13
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Diode Dynamics SL1 LED bulbs... WAYYYY Better than stock with great cutoff.... work better than the HIDs on my Nissan Frontier, and the HIDs on my Frontier are WAYY better than stock. Thinking of replacing thr high-beams now as well with how awesome they work in the stock projectors...plus the low beams are brighter than the high beams... LOL
https://www.diodedynamics.com/low-be...cion-fr-s.html
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 02-13-2020, 04:07 AM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
I'd just warn blindly valuating bulbs as to how much "better" they are just by light output power.
Worth remembering that along seeing better yourself there is bit of not blinding oncoming traffic.
Many stock lights are "worse"/"weak" subjectively because they are made to legal requirements/standards by specific light output and beam shape.
Seeing way too often on highways cheap-modded reusing stock reflectors not fit for specific bulb type or too powerful bulbs fitted. Makes me wish to especially blind them in turn with high beams or give scare to themselves of head-on crash by weering to their lane. Good if country specific MOT inspection won't pass such, but in many countries inspection might be too lax.
The Following 2 Users Say Thank You to churchx For This Useful Post:
scotto79 (02-13-2020), x808drifter (02-13-2020)
Easiest oil cooler Qwimby1 Engine, Exhaust, Transmission 14 10-22-2018 09:45 PM
Will yellow laminx affect light output?(got em) Pho20 Cosmetic Modification (Interior/Exterior/Lighting) 20 08-02-2017 07:42 PM
Which SC kit is easiest to install? tzbang Forced Induction 51 11-10-2015 12:25 PM
Easiest oil change tzhu07 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 51 04-18-2014 10:27 AM
Will Demon Eyes affect light temperature output? (also the legality) boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2013 05:37 PM
