Old 10-22-2018, 01:08 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Easiest oil cooler
I've read though most of the posts I can find on this. I'm ready for an oil cooler, but wonder if anyone can advise which is the easiest to install. I'd rather not pay a wrench to do it, but have limited garage space and I'm not as limber as I once was. I don't think I could get the front clip off myself, partially because I wouldn't have room or the strength to maneuver it when detached.
Qwimby1 is offline   Reply With Quote
Old 10-22-2018, 01:11 PM   #2
Code Monkey
Drives: Subaru BRZ
I suspect all coolers will require the removal of the front bumper.
Code Monkey is offline   Reply With Quote
Old 10-22-2018, 01:17 PM   #3
strat61caster
strat61caster's Avatar
what's the oil cooler for? track use?
ineedyourdiddly
Old 10-22-2018, 01:53 PM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
If you have issues getting up and down off the ground, I'd say find a DIY shop so you can use a lift. Most oil coolers are very easy to get installed, except maybe the Jackson Racing Dual cooler, or the OEM. Not that they are hard, just more time consuming since you have to drain, refill, and then burp the coolant.
MS, CSCS, TSAC-F, CPT
Old 10-22-2018, 01:58 PM   #5
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
They are easy to install but you gonna have to remove the bumper even for 200 dollar ebay oil cooler....so.....just get ur friend to help you.
Old 10-22-2018, 02:06 PM   #6
JIM THEO
Drives: BRZ 2018
Forester oil to water cooler may be?
JIM THEO is offline   Reply With Quote
Old 10-22-2018, 02:43 PM   #7
jflogerzi
jflogerzi's Avatar
Look at the OEM Oil cooler that use the Throttle body location. Very easy to install and all work is done above the hood. This will only give you a modest bump in protection. Its not meant to cover a serious track car. This will add a bit of extra cooling for a street/canyon carver.
2013 Series 10 FRS #553
Old 10-22-2018, 03:43 PM   #8
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
All will require the front bumper to be removed. Its fairly easy to do. The bumper itself is super light. I wouldn't worry about it.
mistople is offline   Reply With Quote
Old 10-22-2018, 04:39 PM   #9
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
OEM style oil cooler will be the easiest (no bumper removal required). Took about half an hour following along with an installation guide on youtube. Some more time will be required to burp your coolant loop properly, but if you have a no-spill funnel that shouldn't take long at all.
Not suitable for any serious track driving, it will quickly be overwhelmed. I don't track but installed one to get slightly quicker warmups and provide some cooling ability for more spirited street driving.
wolffbite is offline   Reply With Quote
Old 10-22-2018, 05:04 PM   #10
Qwimby1
Yeah, for track use and in Florida to boot.
The Following User Says Thank You to Qwimby1 For This Useful Post:
strat61caster (10-22-2018)
Old 10-22-2018, 05:08 PM   #11
Qwimby1
If I had a friend.
Old 10-22-2018, 05:49 PM   #12
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
OEM style won't be enough for this.
If it mounts to the crash beam like the Jackson there's no plan B thought. Perrin, Full Blow, etc all mount to the plate between the bumper and the metal skid plate.
Just pull that plastic plate off from under the car, mount, reinstall. Requires you to get on the ground though so not sure if that helps.
Old 10-22-2018, 06:56 PM   #13
Easiest? Jackson Racing.
Old 10-22-2018, 07:13 PM   #14
TommyW
TommyW's Avatar
Drives: '13 Whiteout
YEP. That's the one I'll be going with
Easiest/Cheapest way to get more power? PacManTheRS1.0 Engine, Exhaust, Transmission 61 05-10-2018 01:14 PM
Easiest way to prime oil system mhiscott Engine, Exhaust, Transmission 12 03-18-2017 01:52 PM
Which SC kit is easiest to install? tzbang Forced Induction 51 11-10-2015 12:25 PM
Easiest oil change tzhu07 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 51 04-18-2014 10:27 AM
Easiest way to get to the over-pipe? Doing an install... seven Engine, Exhaust, Transmission 7 02-03-2013 07:38 AM
