| Member's Car Journals Car journals by our members. |
Drives: 2013 WRB BRZ Limited
HeresMyMind's 13' BRZ Limited Build "ID-0"
This car will be up for sale soon!
The complete modification list: Performance: -OZ Ultraleggera 17x8 +48 Wheels w/ conti extreme sport contacts -Perrin 2.5" Resonated cat back -Motiv HFC Front Pipe -Motiv Overpipe -Supertek High Flow Intake Pipe -K&N Air Filter -Perrin front sway bar -OFT V2 with Stage 2+ V4.0x Flash -KW V3 Coilovers w/ Verus Camber/ top hats -2008 Brembos just rebuild, brembo sport pads, brembo rotors, powdercoated high visibility yellow -Open Source Stage 1 tune that passes emissions. Exterior: -42% window tint -STI-r headlight clear lens swap -Perrin Stubby Antenna -Debadged -OEM JDM Valeo LED fog lights -OEM JDM Rear Fog light hooked up -Replace Front/Rear Blinkers + Reverse Lights/Plate Lights with LEDs -OEM JDM side markers -STi OEM front lip -STi OEM Side Skirts -Bayson STi Rear Spats -STi OEM Rear Diffuser -STi tS front/rear pin-striping -Tom's Clear Tails -STi OEM front/rear badging -Hella Sharptone Horns Interior: -Sony XAV-AX100 w/ backup camera installed -JL Subwoofer + Kenwood Amp =Focal 3 way component set w/ 4 channel amp. -OEM Red foot well lighting -RC Black / JDM Interior dash / trim and traction control buttons -Rear set platform for amps to mount under, and for storage. rear seat in tact -Weathertech Floor Mats -2020 BRZ Homelink Mirror Last edited by HeresMyMind; 09-19-2021 at 11:43 AM. |
#2 |
The day it was delivered to me at home. 100% stock and ready for the modifications to begin.
-B
#3 |
Debadged Rear End:
#4 |
Installed: Perrin Stubby. Who said size doesn't matter??
-B
#5 |
pessimistic skeptic
#6 | |
(What was that)
Drives: ultramarine Scion FR-S
#7 |
My antenna reception has been fine. I made sure to back the insert screw out as much as possible then put a tiny drop of locktight in it to hold the screw in the antenna.
As far as the wax there was built up wax in the lettering on the badges. Around the antenna base. Along the window/door sills (black parts). It was also built up around the edges of the clear vinyl near he kick panels and around the black trim on the bumper. -B |
#8 |
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Hey, you're from Connecticut! Maybe I'll see you around sometime.
| The Following User Says Thank You to Si_Chris For This Useful Post: | HeresMyMind (10-28-2017) |
#9 |
Today I added red footwell lighting, the OEM subaru kit was 130$. so With some extra wire I had, solder, heat shrink and 2 8" strips of red leds, I now have a <20$ kit. I wired it to the Clock illumination wires, (purple = positive, black = ground). They do not dim though.
-B |
#10 |
I installed STi-r clear lenses on the OEM projectors, new bulbs are on the way to replace the 4 year old faded d4s bulbs.
Doing this mod replaces the oem projector lenses which cause the cutoff to be foggy/blurry. This makes for a more crisp / blue cutoff. Because I am a retrofitter it only makes sense to do this! It also adds a bit more intensity in the center. I then installed an OEM front license plate bracket to give the local police 1 less reason to pull me over. I also installed genuine Subaru "STi" valve caps because it had none when I got it. -B |
#11 |
I traded some headlight work for a set of wheels for the car. They arent my first choice of wheel but they are pretty nice looking.
Advan RG2's 18x7.5 +48 w/ falken 225/40r18 tires. -B
#12 |
I pulled in a few side jobs over the last week and got smoked side markers and 42% tint all around. (35% or higher is legal in CT)
-B |
#13 |
Stereo added. absolutely love having apple carplay.
I also purchased some RPF1s for autocross season next year. -B ![]()
#14 |
I did a few things over the last 2 weeks. I painted the calipers a gloss black using a POR-15 paint. I put the RPF1s on after scrubbing them down and then waxing them. And I installed the Baja Designs Squadron Sport Fog lights w/ rally innovation brackets. They were FAR from a perfect fit, but after lots of trimming I am very happy with the result. I also created home made center caps for the rpf1s using 85 cent knock-out seal's from home depot, and some left over silver vinyl I had laying around. Not bad for under 4$ worth of materials.
-B |
| Car failed inspection; told I need to "build up the drive cycle"? | irocz0r | Issues | Warranty | Recalls / TSB | 11 | 06-22-2017 08:25 PM |
| TWINCHARGED (Supercharged & Turbocharged) Widebody "WTF-86" 86/FRS *MASSIVE* build :D | WTF | Member's Car Journals | 224 | 08-18-2016 09:39 PM |
| Meet "Cloud" Errol's FR-S Build Thread | RainEG | Member's Car Journals | 12 | 08-01-2014 05:18 PM |
| BRZ "Limited" STX build | xDanger_208x | Member's Car Journals | 48 | 04-21-2014 11:38 PM |
