Drives: 2020 Subaru BRZ
Removing fuel from tank, best way
Whats the best or easiest way to get the fuel from my tank. I was considering jumping the fuel pump relay with the fuel line disconnected from The engine. Any sjggestions.
Thanks Roger |
Drives: FR-S,GTI
It might not be the best way, but the easiest way is to drill a hole into the bottom of each tank.
Drives: 13 White MT FR-S
Drop it and dump it out
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Drive it until empty.
Drives: 2015 BRZ Limited
You can disconnect the starter fuse, disconnect one of the fuel lines, and continuously start the car and stop it, over and over again while the fuel line shoots fuel out of it and hopefully into a bucket. It might take awhile depending on how much fuel you have left in the tank. We had a little under a quarter left when we tried, and it maybe took two of us (one holding the bucket and one in the car turning it over) ~30 minutes.
EDIT: I just read your question, I had only read the title of the post. You have the right idea.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
Drives: 2013 FRS
Make the fuel pump work for you, or drop it as is.
If dropping the tank as is, remember there is likely a check valve in the filler neck. It's possible you could remove the filler neck hose and stick a long screwdriver in to relieve the check valve, and empty some of the gas that way with it still in the car. |
Drives: Q5 + BRZ + M796
#9 | |
Thanks |
#10 | |
#11 | |
#12 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
If it's the same as a 2018 the fuel pump is controlled by an ecu. No old school relay terminal jumping possible.
If you accessed the fuel pump ecu, and disconnected the connector you could supply power and ground to the fuel pump yourself. Then you could just catch the fuel from wherever you disconnected the fuel line
Work Hard. Play Hard.
2016 Oceanic |
#13 |
JDM Vaping Stance Nation
Drives: 2013 White
Stick a hose in and suck it out with your mouth?
Clueless
#14 | |
Or, just write off the $20 in fuel since your time must be worth something.
| DIY : Draining the gas tank - Methods to empty fuel tank | Mermoz | DIY (Do-It-Yourself) Guides | 13 | 10-09-2025 02:56 PM |
| Larger Fuel Tank | go_a_way1 | Engine, Exhaust, Transmission | 33 | 11-18-2016 07:53 PM |
| Draining the fuel tank | Fricke | Engine, Exhaust, Transmission | 13 | 06-20-2016 11:52 PM |
| Out of fuel with 2 gallons in the tank | Simisimi | Issues | Warranty | Recalls / TSB | 31 | 06-18-2015 03:30 PM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 03:39 PM |
