Old 11-10-2015, 07:59 AM   #1
Fricke
Drives: Toyota GT86
Draining the fuel tank
Hi there thought that I should drain out all the e85, now that the car djust sitting ther in build season.
So I thought that I could djust plug a battery direct too the fuel pump and draining it out whit the fuel line.
But does anyone know witch of the four is the blue and black line for + and - on the fuel pump from the top of the casings?
Djust to tiered to open up the unit to check for myself
Borough that picture from someone here.
Fricke is offline   Reply With Quote
Old 11-10-2015, 06:52 PM   #2
steve99
Even if you used pump to drain their will probably be a few litres left in tank.
Modern fuel systems are pretty well sealed so would be very difficult for air or moisture to enter system if fuel system is not pulled apart or tank cap left off.
The e85 should be fine if its in a sealed enviroment, maybe add some Ethanol fuel stabilser although the only guy who had problems with his fuel filter was running additives apararantly.
If it left sealed it shoul be fine for months.
http://lucasoil.com/products/fuel-tr...th-stabilizers
Old 11-10-2015, 07:13 PM   #3
swarb
Someone mentioned to me to just pull a fuel line from the engine bay. Turn on the car (NOT THE ENGINE!) and let the fuel pump prime and pump all the fuel out. Not sure if it is a good idea though, maybe someone else can give input on this idea.
Old 11-10-2015, 07:24 PM   #4
roddy
roddy's Avatar
Drives: '13 Ultramarine
Did you check the bottom of the tank for drain plug(s)?
Old 11-13-2015, 03:31 AM   #5
Fricke
Drives: Toyota GT86
Want to drain, because the Swedish E85 kludge up the injectors if it's sitting for a while
It gets too a pink/purple much because off the color adaptive that makes the E85 pink in color.
Old 11-13-2015, 03:35 AM   #6
Fricke
Drives: Toyota GT86
That was the first things I did try, and fuel pump cuts the power if it's not building pressure
Only getting out a bout a deciliter at the time, and that's gone take me several hours to drain.
Old 11-13-2015, 03:37 AM   #7
Just open the cap on both sides and siphon it out.
Sometimes, doing it the oldschool way is the easiest
Or, let it idle until it stalls.
Old 11-13-2015, 03:37 AM   #8
Fricke
Drives: Toyota GT86
No I haven't, but I doubt that I have one, plastic thanks don't have it for most times.
Old 11-13-2015, 03:45 AM   #9
steve99
That a good point your may have extra additive for low temps and colour ect. The E85 I use is clear.
maybe might be best to run tank down / fill with petrol and flash petrol tune for winter ??
Old 11-13-2015, 05:02 AM   #10
Fricke
Drives: Toyota GT86
Exactly what I'm planning to do
Run some good old plain 98 octane through everything.
Old 11-13-2015, 05:05 AM   #11
Fricke
Drives: Toyota GT86
What caps are we talking about Micke, tell me more
Old 11-13-2015, 06:06 AM   #12
The one in the pic you posted. Turn counter clockwise, and the assembly comes out, and you can access the inside of the tank.
Old 11-13-2015, 03:02 PM   #13
Fricke
Drives: Toyota GT86
Of course did understand what you meant, djust after I posted
Thanks Micke
Old 06-20-2016, 11:52 PM   #14
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Wouldn't it be just as easy to run a 1/4 of 93 through it till the gas light kicked on. Should be gone by then? Or is it me being half asleep and everything seems to work simpler
tofurun is offline   Reply With Quote
Out of fuel with 2 gallons in the tank Simisimi Issues | Warranty | Recalls / TSB 31 06-18-2015 03:30 PM
Stock In-Tank Fuel Filter Degradation sw20kosh Engine, Exhaust, Transmission 96 07-28-2014 03:36 AM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
AEM High Flow In-Tank Fuel Pump JPxM0Dz Engine, Exhaust, Transmission 0 04-13-2013 12:15 PM
“saddle-shaped” fuel tank ft86Fan Engine, Exhaust, Transmission 13 06-26-2012 04:22 AM
