Old 01-12-2020, 12:20 PM   #1
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
Removing fuel from tank, best way
Whats the best or easiest way to get the fuel from my tank. I was considering jumping the fuel pump relay with the fuel line disconnected from The engine. Any sjggestions.
Thanks
Roger
Rabrooks is offline   Reply With Quote
Old 01-12-2020, 12:50 PM   #2
WNDSRFR
Drives: FR-S,GTI
It might not be the best way, but the easiest way is to drill a hole into the bottom of each tank.
Old 01-12-2020, 01:05 PM   #3
Rabrooks
Rabrooks's Avatar
Ah, no.
Old 01-12-2020, 02:00 PM   #4
ML
ML's Avatar
Drives: 13 White MT FR-S
Drop it and dump it out
Old 01-12-2020, 07:00 PM   #5
Ernest72
Drive it until empty.
Old 01-12-2020, 09:12 PM   #6
FunnyGopher
Drives: 2015 BRZ Limited
You can disconnect the starter fuse, disconnect one of the fuel lines, and continuously start the car and stop it, over and over again while the fuel line shoots fuel out of it and hopefully into a bucket. It might take awhile depending on how much fuel you have left in the tank. We had a little under a quarter left when we tried, and it maybe took two of us (one holding the bucket and one in the car turning it over) ~30 minutes.
EDIT:
I just read your question, I had only read the title of the post. You have the right idea.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 01-13-2020, 12:43 AM   #7
Stomachbuzz
Drives: 2013 FRS
Make the fuel pump work for you, or drop it as is.
If dropping the tank as is, remember there is likely a check valve in the filler neck.
It's possible you could remove the filler neck hose and stick a long screwdriver in to relieve the check valve, and empty some of the gas that way with it still in the car.
Stomachbuzz is offline   Reply With Quote
Old 01-13-2020, 01:31 AM   #8
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
What's the goal/point?
https://www.ft86club.com/forums/showthread.php?t=130132
Old 01-20-2020, 09:38 PM   #9
Rabrooks
Rabrooks's Avatar
The car is totaled and it has 3/4 tank of gas. I want to get it out so I can use it in one of the other cars. I dont want to drop the tanks because I'll have to raise the car too high. I was hoping to use the fuel pump in some way. With my corvette, I can jump a fuel pump relay and gas flows freely. I tried that with BRZ with no luck. I'm sure I just had the wrong fuse or relay. Surely someone has done this.
Thanks
Old 01-20-2020, 10:06 PM   #10
FunnyGopher
Thanks
See my previous post.
Old 01-20-2020, 10:09 PM   #11
Irace86.2.0
Thanks
Siphon the tank. You won’t get it all, but who cares about a few dollars in gas?
Old 01-21-2020, 10:33 AM   #12
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
If it's the same as a 2018 the fuel pump is controlled by an ecu. No old school relay terminal jumping possible.
If you accessed the fuel pump ecu, and disconnected the connector you could supply power and ground to the fuel pump yourself. Then you could just catch the fuel from wherever you disconnected the fuel line
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 01-21-2020, 10:47 AM   #13
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Stick a hose in and suck it out with your mouth?
Clueless
YamahaR86 is offline   Reply With Quote
Old 01-21-2020, 11:41 AM   #14
Thanks
If totaled then what is wrong with just drilling a hole in the tank?
Or, just write off the $20 in fuel since your time must be worth something.
DIY : Draining the gas tank - Methods to empty fuel tank Mermoz DIY (Do-It-Yourself) Guides 13 10-09-2025 02:56 PM
Larger Fuel Tank go_a_way1 Engine, Exhaust, Transmission 33 11-18-2016 07:53 PM
Draining the fuel tank Fricke Engine, Exhaust, Transmission 13 06-20-2016 11:52 PM
Out of fuel with 2 gallons in the tank Simisimi Issues | Warranty | Recalls / TSB 31 06-18-2015 03:30 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
