Old 12-25-2019, 03:59 AM   #1
MICHAEL450f
Drives: 2018 BRZ
Car won’t start after turbo install.
I installed a jdl turbo kit with delicious ebc on my brz and now it just cranks over. It ran for about 10 seconds then died. I’ve looked over everything and can’t seem to think of what would be wrong. It is throwing an evap code. Anyone have any ideas?
MICHAEL450f is offline   Reply With Quote
Old 12-25-2019, 05:21 AM   #2
GenRuleAThumb
GenRuleAThumb's Avatar
Drives: 2014 FR-S
is the fuel pump priming?
GenRuleAThumb is offline   Reply With Quote
Old 12-25-2019, 08:48 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Switch the MAP sensor back to stock, make sure your pcv and crankcases lines are all hooked up correctly
Old 12-25-2019, 01:13 PM   #4
MICHAEL450f
Drives: 2018 BRZ
Fuel pump is priming and I’ll try the stock map sensor. Double checked all lines and everything seems to be good.
Old 12-25-2019, 01:16 PM   #5
tomm.brz
Drives: brz 2017 hksv2
of course remember to change the scaling of the map sensor on the tune, if you have an higher Bar map now
otherwise it will not start again
Old 12-25-2019, 01:22 PM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Is everything reinstalled? You didn’t remove the ECU on the passenger side of the engine and leave it unbolted, did you?
Old 12-25-2019, 03:46 PM   #7
MICHAEL450f
Drives: 2018 BRZ
Car fired right up with the stock map sensor. Thank you guys for the advice. Would it be safe to drive the car home on the stock sensor if I kept the rpms low so it doesn’t build more boost than the stock sensor can handle? My tune is from delicious so I’ll have to call tomorrow if they’re open.
Old 12-25-2019, 03:53 PM   #8
tomm.brz
yes just stay out of high boost
what sensor did you have before?
Old 12-25-2019, 04:52 PM   #9
MICHAEL450f
Drives: 2018 BRZ
I have a 3 bar that cane with the kit
Old 12-25-2019, 05:05 PM   #10
tomm.brz
if it started with the stock map without a modification in the tune, that s your problem
didn t you tell Delicious you had a 3bar map?
Old 12-25-2019, 07:20 PM   #11
MICHAEL450f
Drives: 2018 BRZ
I did tell them when I ordered it, I’ll have to give them a call and see what’s going on.
Old 12-25-2019, 07:35 PM   #12
Irace86.2.0
Does your tune file say 3-bar in the script? Mine said 4-bar, and said 220cc then 770cc and said flex fuel, as I added those components.
https://datazap.me/u/jirace/v8-flex-...?log=0&data=29
Look at my files from DataZap.
Old 12-25-2019, 07:40 PM   #13
tomm.brz
if it started with stock map that means surely 10000% they forgot to scale for it
grams throttle body install, won't start jdair28 Engine, Exhaust, Transmission 34 06-26-2019 12:31 PM
No-start after clutch install chargedup Engine, Exhaust, Transmission 11 03-27-2017 06:22 PM
Car won't start after intake install ajh88 Issues | Warranty | Recalls / TSB 23 01-30-2017 06:34 PM
HELP! After Unichip install, car won't start!!! husker741 Issues | Warranty | Recalls / TSB 21 01-10-2015 11:50 PM
Schematic for remote start install? empower-auto Electronics | Audio | NAV | Infotainment 3 07-31-2012 06:13 PM
