Old 12-24-2019, 12:35 AM   #1
exTempus
Drives: Scion FRS
ARF Readings
I got the P0171 and P1171 codes. Running Stage 2 E85 tune for a while now but recently swapped catback. Re-flashed the tune, but saw AFR is at 20% while idle and LTFT is at 15%.
I also did the sound generator delete. Thinking it could be the intake, I tightened the intake plug (was kind of loose).
Is this normal or do I have an exhaust leak? Already reset the codes.
exTempus is offline   Reply With Quote
Old 12-24-2019, 04:05 AM   #2
steve99
Check you actually flashed to e85 tune and not petrol tune make sure its latest oft v4 tune ie doenload it from site
Check for exhaust or intake leaks
Old 12-24-2019, 10:50 AM   #3
jflogerzi
jflogerzi's Avatar
We're you completely empty? Sometimes it takes a mile or 2 to fully get rid of all the remaining 91/93. Drive it like a grandma till you see your fuel trims stabilize. Also do what Steve recommend above as well
2013 Series 10 FRS #553
Need help with my OFT Readings juniorrr Scion FR-S / Toyota 86 GT86 General Forum 3 03-10-2019 07:10 PM
Need help with my OFT Readings juniorrr Engine, Exhaust, Transmission 0 03-10-2019 04:21 PM
High Afr readings. ristar Software Tuning 4 03-06-2017 04:53 AM
OFT strange IAM and FLKC readings...any help? Phil0rd Software Tuning 1 01-20-2017 03:14 AM
Weird O2 readings sw20kosh Software Tuning 22 05-15-2014 05:49 PM
