Old 01-20-2017, 02:55 AM   #1
Phil0rd
Drives: 2016 WRB BRZ
OFT strange IAM and FLKC readings...any help?
USDM '16 BRZ Manual, Calibration Code F40C
Running OTS E85 UEL Tune with Gruppe-s UEL header
I recently started to pay close attention to the data displays and found some disturbing numbers:
--Adv Multiplier: 0
--FLKC: -5, jump to 5 or 0 if I let go the throttle (I guess -5 ~ 5 is the max and min OFT can display, data log actually shows -100)
--KC Learned: 0, quick blip if I step on the throttle
--O2S2: 0
Log here:
http://datazap.me/u/phildu/f40c-e85-uel-1
1st gear drive around
From the numbers it looks like there is a serious knock problem, but the car drives perfectly fine. Never had any sign of knock. Knock Correction is always 0, unless I kick the throttle on high gear low RPM, which bring it to a very small value.
Things I have tried:
--Keep OFT updated, now the firmware is 1.40
--Update the template. Can't find this on OFT website anymore, but tried this one uploaded by Steve: http://www.ft86club.com/forums/showthread.php?p=2545079
--Switch to original tune and back. When running the original tune, ST Fuel Trim rises drastically, so I guess the at least the first O2 sensor is working properly..?
Any input would be helpful, thanks!
Phil0rd is offline   Reply With Quote
Old 01-20-2017, 03:14 AM   #2
Boomerang
86
Boomerang's Avatar
some logging doesn't work on new Roms
known issue
contact Shiv
Good luck
-5 degrees flkc on oft stage 2 uel Texas2016Frs Software Tuning 18 11-05-2016 07:09 PM
Decibel readings of 2017 BRZ vs other cars. ~el~jefe~ BRZ First-Gen (2012+) — General Topics 3 11-03-2016 10:33 AM
Positive FLKC? BFIFE22 Software Tuning 7 09-26-2016 04:25 PM
Negative FLKC but IAM stays at 1 Tectoniic Software Tuning 6 01-10-2016 04:33 AM
Weird O2 readings sw20kosh Software Tuning 22 05-15-2014 05:49 PM
