Old 05-13-2014, 01:08 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Weird O2 readings
Do you see anything wrong with the below picture? Custom Map M is my LC2 wideband (yellow line). I have been told this looks weird because the wideband should be reading richer than the stock O2 sensor.
Just wanted to get a general consensus on 1. if it is abnormal and 2. if it is, what is causing this anomaly. I would like to remedy the situation.
I have already:
1. Replaced my stock O2 w/ a buddy's stock Brz O2 sensor. Same result as the picture below so that rules out the stock O2 being bad.
2. Recalibrated the wideband in free air. No change.
Yellow = wideband
Red = stock O2
Old 05-13-2014, 01:18 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
When you say this:
Originally Posted by sw20kosh View Post
I have already:
1. tried a buddy's stock O2 sensor. Same result.
2. Recalibrated the wideband in free air. Same result.
What do you mean?
Do you mean that your wideband sensor is off from another by the same amount as the stock O2, or that the other wideband is off the stock O2 by the same amount? It's hard to determine which one you mean.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-13-2014, 02:04 PM   #3
Ross
Drives: 85 corolla gts
I have found on force induction cars that the factory sensor is rarely anywhere near accurate as back pressure increases. I stop worrying what the factory sensor says and go by my wideband in open loop. I do verify there is not any voltage offsets going on before I trust the wideband as well.
Ross is offline   Reply With Quote
The Following 3 Users Say Thank You to Ross For This Useful Post:
Sportsguy83 (05-15-2014), sw20kosh (05-13-2014), Xero-Limit (05-15-2014)
Old 05-13-2014, 02:09 PM   #4
sw20kosh
Originally Posted by Kodename47 View Post
When you say this:
What do you mean?
I re-worded it. Thanks.
Old 05-13-2014, 03:04 PM   #5
sw20kosh
Back pressure! @jamesm
Voltage offsets? Easy to check this?
Old 05-13-2014, 03:29 PM   #6
Ross
A lot of the fi cars I will tune have a wideband already installed. I will verify the ecu is seeing the same voltage as the wideband is putting out. Then I will make the custom tables. It is not super common to see this issue, but some installs may need to be corrected do to connection quality, signal noise, ect. If I am using my lm2 then it is a non an issue.
Old 05-13-2014, 03:38 PM   #7
jamesm
I believe the ptuning kit is unique in that the front o2 sensor stays before the turbo whereas with most others it's relocated to the downpipe. I definitely suspect that the backpressure under load is what's causing it to peg rich. You don't see that with other turbo kits where it's relocated. In my experience the stock o2 is always off but it usually reads leaner than the wideband, not richer.
I never make custom scaling for the front o2, just use ecutek's provided scaling and tune off of the wideband.
The Following User Says Thank You to jamesm For This Useful Post:
Old 05-13-2014, 03:53 PM   #8
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Are you using an analog ground?
post_break is offline   Reply With Quote
Old 05-13-2014, 04:11 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
I would always take the WBO2 reading over the OEM one. Just because it usually reads leaner doesn't mean that it always will.
As said, it will depend on where both sensors are located too. The further back the WBO2 the more likely it is to read leaner.
I'm with Jamesm in the sense that I would leave the ECUtek advised O2 config as it is and then use a custom map if required to correct fuelling base on the WB if needed.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Old 05-15-2014, 12:38 AM   #10
sw20kosh
I am sorry but what does this mean? I am grounding the LC2 to the chassis.
Old 05-15-2014, 09:12 AM   #11
post_break
post_break's Avatar
In the manual it says you must use an analog ground, like a ground the ECU uses otherwise your readings will be off. If you use a power or chassis ground your readings will be wrong.
Old 05-15-2014, 09:35 AM   #12
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@welllam I think this thread might interest you...
The Following User Says Thank You to Sportsguy83 For This Useful Post:
welllam (05-15-2014)
Old 05-15-2014, 10:16 AM   #13
stugray
Drives: 2013 GBS BRZ Limited
"Grounding" is a science all to itself.
Cars typically use chassis as a "Ground reference" and a "Current return path".
For sensitive electronics (O2 sensors) they need a proper "ground reference" that tells the circuitry what voltage is "Zero volts" as far as the system is concerned.
When you use car chassis as this ground reference, then it is not always at "zero volts" with respect to the rest of the car because the voltage of any particular point in the chassis is dependent on how much current is flowing through chassis and where the current is flowing.
So if you "reference" the O2 sensor to car chassis close to the sensor, then the ground can move up or down depending on if (for example) the radiator fans are on or off. This is because current flowing through the chassis causes voltage drops in this reference.
For the more sensitive sensors, you should run a dedicated "ground reference" from the sensor to the unit reading the sensor.
If you use chassis for this, then the "zero volts" reference is not always at "true zero".
If anyone cares and is confused by this, I could make a diagram.....
The Following 2 Users Say Thank You to stugray For This Useful Post:
SirBrass (05-15-2014), Sportsguy83 (05-15-2014)
Old 05-15-2014, 12:18 PM   #14
welllam
Drives: STi
If i use the same ground for the aem gauge and also the same for the output ground, is this the same reference?
@Sportsguy83 i connect my ground of both to the same fuse box bolt that you uses and also poeer from the fuse top of the drl. So connection wise it should be similar. Just dont get it...
welllam is offline   Reply With Quote
The Following User Says Thank You to welllam For This Useful Post:
Weird Noise FloridaBRZ BRZ First-Gen (2012+) — General Topics 7 04-25-2014 08:35 PM
Weird Noise??? caradd Issues | Warranty | Recalls / TSB 3 11-01-2013 11:42 PM
FR-S is doing weird stuff Apoc Issues | Warranty | Recalls / TSB 16 03-30-2013 11:00 AM
is it weird? slidethis Scion FR-S / Toyota 86 GT86 General Forum 11 01-14-2013 01:07 AM
This might sound weird mrha BRZ First-Gen (2012+) — General Topics 10 10-06-2012 06:06 AM
