Old 03-05-2017, 05:09 PM   #1
ristar
High Afr readings.
Hello all, first time poster here. I'm seeing an interesting reading on my afr with oft. Stock 2013 fr-s with a drop in filter. I switched to running the oft stage 2 el e85 map about a month ago and I'm seeing the afr shoot up to 20:1 when I lift off the throttle. I don't have a data log handy, living out of a hotel and don't have the appropriate cable, I'll work on getting that if need be, but I'm wondering if a sensor might be at fault or something like, it happens in both closed and open loop fueling, and it seems to happen immediately, lift off throttle and it goes right up to 20 on the dot with no fluctuations, I don't hear or feel the engine running abnormal though. Thoughts?
ristar is offline   Reply With Quote
Old 03-05-2017, 05:17 PM   #2
elBarto
elBarto's Avatar
Drives: Toyota GT86
It's normal, when you lift of the throttle no fuel is being injected, only air. The sensor can only read at a maximum of 20:1
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
guybo (03-05-2017)
Old 03-05-2017, 05:18 PM   #3
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
completely normal. when you lift off the throttle, fuel cut off activates until the rpm returns to idle.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 03-05-2017, 05:19 PM   #4
Trust86
Drives: 2016 Halo FRS
Check it at wot
Trust86 is offline   Reply With Quote
Old 03-06-2017, 04:53 AM   #5
ristar
OK that works for me, thanks all.
@Trust86 it seems ok at WOT, high 12 to very low 13. Not unreasonable I imagine
OFT strange IAM and FLKC readings...any help? Phil0rd Software Tuning 1 01-20-2017 03:14 AM
Decibel readings of 2017 BRZ vs other cars. ~el~jefe~ BRZ First-Gen (2012+) — General Topics 3 11-03-2016 10:33 AM
High rev Hempo Engine, Exhaust, Transmission 13 12-23-2014 06:01 PM
Weird O2 readings sw20kosh Software Tuning 22 05-15-2014 05:49 PM
