Old 11-03-2019, 09:35 PM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Installed: TWS T66F in 17x8, Stock Tire Size
Oem+ build, used lightweight hankook ventus v12 in stock size to retain nimbleness.
Lost 7lbs per corner
Because of the lightness, car feels more “floaty” which takes getting used to, but the grip and nimbleness is definitely better.
Loving that it aint a stretch at all, and im sticking with OEM suspension.
leevanf is offline   Reply With Quote
The Following 10 Users Say Thank You to leevanf For This Useful Post:
beltax90 (11-18-2019), Iceman (11-13-2019), new2subaru (11-04-2019), Racecomp Engineering (11-04-2019), RToyo86 (11-06-2019), SuperTom (01-03-2020), Tristor (11-04-2019), why? (11-06-2019), Will BRZ (11-04-2019), Yoniyama (11-19-2019)
Old 11-04-2019, 09:51 PM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
Nice wheels! Would you consider a lip or splitter for a bit of downforce?
Old 11-04-2019, 09:59 PM   #3
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Looks really good. 7 pounds is a lot!
Will BRZ is offline   Reply With Quote
Old 11-04-2019, 10:03 PM   #4
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
These look amazing
Elliotw is offline   Reply With Quote
Old 11-05-2019, 10:35 AM   #5
jredders
Drives: 2017 Subaru BRZ Limited with PP
Damn those look nice, but are expensive.
jredders is offline   Reply With Quote
Old 11-05-2019, 04:25 PM   #6
gravitylover
Try dropping the pressure a little bit at a time and see if the floaty feel goes away.
The Following User Says Thank You to gravitylover For This Useful Post:
new2subaru (11-05-2019)
Old 11-05-2019, 05:36 PM   #7
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
I really want these in 18x9.5. So cool.
mistople is offline   Reply With Quote
Old 11-06-2019, 07:15 AM   #8
leevanf
leevanf's Avatar
Im considering a lip spoiler but im trying to look for a very thin one!
Old 11-06-2019, 07:15 AM   #9
leevanf
leevanf's Avatar
Ill try that. Currently on the recommended 35s
Old 11-06-2019, 07:42 AM   #10
new2subaru
Weight Weenie
Drives: 15 FR-S
I know you would like to stay OEM+ What about a TRD front lip/body kit. If painted the body colour it looks really nice. It OEM and not to racey looking.
https://www.86worx.com/trd-front-lip.html
More pics
https://www.evasivemotorsports.com/mm5/merchant.mvc?Screen=PROD&Product_Code=TRD-MS341-18002
Modellista kit
https://www.86worx.com/modellista-front-lip.html
Old 11-06-2019, 04:46 PM   #11
gravitylover
Things like sidewall stiffness and rubber compound will play a big part of how a car this light feels. Most of these tires are intended for cars that are 500 pounds, or more, heavier than these cars so the recommended pressure will be different due to them having a beefier casing to support the heavier car. I'd try by dropping it a 1/2 psi at each corner (when cold), the rear will probably need to go down more than the front.
Old 11-17-2019, 11:25 PM   #12
leevanf
leevanf's Avatar
Thats brilliant. I notice the car feels less floaty after a few weeks without air (at about 33 psi)
The Following User Says Thank You to leevanf For This Useful Post:
gravitylover (11-18-2019)
Old 11-18-2019, 12:39 AM   #13
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Wow. Those look great. What are the offsets?
LSxJunkie is offline   Reply With Quote
Old 11-18-2019, 12:43 AM   #14
leevanf
leevanf's Avatar
They are
+42s. No rub, just the right flush on fenders for me.
17x8.25 tire size 225/45, 235/45 or 245/40? tracerit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-24-2022 01:03 PM
WTB: Stock size tire - a set of 4 FMJ Canada Classifieds 3 06-22-2018 02:25 PM
Recommend tire size for 17x8.5 +20? yutinggao Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-21-2016 10:21 AM
Tire size for 17x8.5 +32 +42 giraffee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-06-2013 08:17 PM
Which tire size for 17x8.5? giraffee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-11-2013 07:26 PM
