Drives: Subaru BRZ
Help, accident car rear alignment.
Hi,
Just bought my car(recondition from Japan) few months ago and notice something wrong with the alignment. Check at workshop and they told me that car had been in accident before, so I buy the recondition report and found out the car right side collide and damage before they sell it. ![]() ![]() Now, it had been repaired, but still the final alignment adjustment issue is there. Here is the latest alignment done last week : ![]() So, the shop advise me to change to adjustable lower control arm and rear toe arm. What do you guys think? Any advice? |
Normally I would say go after the shop that did the repair but that won't work in this case. Get your shop to fix it and consider it a lesson in why "reconditioned" cars can be a problem.
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (10-07-2019) |
You have a bent subframe (or maybe upper control arm), the adjustable parts are a bandaid for something that far out of whack, if it's just a daily driver is probably fine but if you want to track or drift you'll want to fix it right eventually. Toe arm may Not be necessary, it already has a large factory adjustment range but it's hard to tell because they put so much toe in on your picture, zeroing that right rear toe will help the camber a bit, I wonder how honest they are being...
Thanks
Looks like the guy drifted in a barrier and curb. That can cause significant damage that is a headache to fix.
Take it to a shop that can measure the frame and find out what really needs fixing and not just throw parts at it.
| The Following 4 Users Say Thank You to ZionsWrath For This Useful Post: |
[insert cool phrase here]
Drives: BRZ Premium
As said before it's best to fix the frame. Or at least get it checked. If it's just suspension parts, that's easy. If the frame is jacked then replacing suspension part will just wear out over time. Then your back to square one.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following 3 Users Say Thank You to Mr.ac For This Useful Post: |
| New Rear Tires & Alignment now unstable | EzyBreezy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 05-28-2019 12:53 AM |
| rear alignment tools recommendation | stlgrym3 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 03-06-2018 10:18 AM |
| CA rear end accident , Not at fault. Have a Question | PhoenixGT86 | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 01-03-2017 08:46 AM |
| Rear camber assymmetry and alignment issues | ofuts | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 02-02-2015 12:46 PM |
| Rear Camber/Alignment Question | anewprelusion | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-25-2013 11:39 PM |
