Old 03-06-2018, 02:35 AM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
rear alignment tools recommendation
i just lowered my car with Apexi EXV N1 coilovers for about 1.5 inches front and rear, front alignments are within factory specs now but the shop could not do anything with the rear unless i install a different rear control arm. any recommendations on what kind of tools out there that can help me adjust rear alignment. right now my rear is about 2.5 degrees negative camber.
stlgrym3 is offline   Reply With Quote
Old 03-06-2018, 02:49 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Nothing really besides an aftermarket lower control arm.
The Following User Says Thank You to Mr.ac For This Useful Post:
Boomerang (03-06-2018)
Old 03-06-2018, 02:57 AM   #3
stlgrym3
what are some most popular ones? not looking for crazy adjustments, just to get rid of negative cambers.
Old 03-06-2018, 04:19 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Cheapest are stock alike spc/whiteline/eibach, from better ones i'd go for velox/verus one.
P.S. There IS way to change camber in rear w/o aftermarket adjustable LCA, but it involves changing/pressing in eccentric bushings, which are PITA to adjust, takes more time to install (=more charged for work), so better go straight away for adjustable LCA. Something like SPC's for $230 is cheap enough imho.
The Following User Says Thank You to churchx For This Useful Post:
86kahl (03-06-2018)
Old 03-06-2018, 08:51 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
If you don't have to worry about corrosion (you are in socal) get that good shit, SPL
Old 03-06-2018, 10:18 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
You might just run with -2.5 camber, zero toe, and rotate tires every once in a while (theoretically only ONE properly timed rotation is necessary). -2.5 is streetable IMO, and better for ultimate lateral grip! With zero or minimal rear toe the "camber wear" you get might not be that bad.
Wheel alignment Tools Walla Walla Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-24-2017 08:07 AM
Alignment Recommendation ZZT86 AUSTRALIA 6 04-19-2016 07:07 AM
Rear camber assymmetry and alignment issues ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 02-02-2015 12:46 PM
Clanking from Rear Suspension After Alignment(w/ KW V3, Cusco LCA, Whiteline Toe Arm) Figo Issues | Warranty | Recalls / TSB 29 10-29-2013 06:09 PM
Rear Camber/Alignment Question anewprelusion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-25-2013 11:39 PM
