Old 09-11-2019, 10:46 AM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Delicious Tuning stage 1 tune
i was planning on selling my BRZ so i reverted everything back to stock, but i still have my Ecutek dongles. i may hold onto the car for bit longer now, i'm not interested in installing aftermarket header so i'm thinking about DT stage 1 tune. that works on stock header correct? is it worth it to flash it?
stlgrym3 is offline   Reply With Quote
Old 09-11-2019, 09:56 PM   #2
Frankz54
Drives: 2019 Toyota GT86
Yes, stage 1 works with your Stock setup.
Frankz54 is offline   Reply With Quote
Old 09-11-2019, 10:23 PM   #3
stlgrym3
Is it worth it to get the stage 1? I’ve had OFT stage 1 before and frankly did not notice any difference. Is the DT stage 1 better?
Old 09-13-2019, 07:36 AM   #4
steve99
Tune on stock car is only mild improvement no matter waht tune system you use
If you want an ecutek stage 1 tune for your car ill create one way cheaper just message me, can have 4 maps with whatever features you want active
Old 09-13-2019, 05:45 PM   #5
tomm.brz
Drives: brz 2017 hksv2
@op
Our steve99 here is pure gold, do with him and you won't regret
Old 09-14-2019, 07:55 AM   #6
stacyu18
Drives: 2014 subaru brz
e85 is the best way to go if you can
stacyu18 is offline   Reply With Quote
Old 09-15-2019, 12:59 PM   #7
Lantanafrs2
Drives: 2013 frs red
I'd go with Steve also. Unless you wanna splurge on a dyno tune at a reputable shop
Old 09-16-2019, 02:54 PM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
Or just flash a (compatible) OFT tune on the car
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-16-2019, 08:38 PM   #9
steve99
If its a auto will work , but any manual tune with th lc\ffs patch upsets ecutek now that your forced to add racrom patch to flash any non stock tune. Unless got tuner version ecutek with compare will take hours to cut and paste all the tables into a non patcged rom, doable but time consuming
Old 09-17-2019, 05:50 PM   #10
stlgrym3
what sets part from Steve's tune from a reputable shop's tune, besides money that is?
Old 09-17-2019, 05:54 PM   #11
Lantanafrs2
Both will be good
Old 09-19-2019, 07:07 PM   #12
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Stage 1 tune with Flex Fuel is always a good setup. Stage 1 by itself does give you decent gains but nothing too crazy as Steve said. Usually pump gas Stage 1 is about a 8-12 hp/tq gain.
Below are the expect results from stock (91 pump gas) to E85 Flex Fuel Stage 1 tune.
Will Delicious Tuning Stage 2 flas work w/ stock header? aznatama Software Tuning 11 05-15-2016 05:42 PM
Stock NA Tune - Motoeast or Delicious Tuning? brillo Software Tuning 9 11-23-2015 12:48 AM
Delicious Tuning is the way to go for a custom tune. Canivideo User/Vendor/Sponsor Reviews, Feedback, Comments 5 01-13-2015 03:47 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
