Old 09-10-2019, 02:13 PM   #1
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
Clicking sound above 2k RPM - helpppp
Hey guys, the old girl is being a bit of a pain lately. Car is making clicking sounds like if you put a zip tie on your bicycle wheel. sound is prominent above 2k RPM and frequency goes up as engine rpm goes up. This happens both on and off throttle. The clicking goes away when i put the clutch in, and returns when i back clutch out. At first i thought it was the TOB (last swapped 10k miles ago, similar symptom but was fixed after the swap). So i spent the money and put in a new TOB thinking maybe i just had bad luck (both TOB are revised version), but nope, not only it didn't go away, now its even more noticeable.
Anyone got any insight to what it might be? the TOB that we took out was pretty smooth, didn't have much slop.
slyphen is offline   Reply With Quote
Old 09-10-2019, 02:18 PM   #2
humfrz
Well, my best guess is that the clutch disk or the pressure plate is defective. Has either of those been replaced?
humfrz
Old 09-10-2019, 02:32 PM   #3
slyphen
Drives: Man
Not this second round. the first time, we did the full clutch job, so everything was replaced a little over 10k miles ago. we also changed the bearing retainer the first go around and inspected when we swapped the TOB the second time.
Old 09-10-2019, 02:51 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Timing chain slap?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-10-2019, 03:10 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
When you guys replaced it, did you follow proper lubrication guidelines?
Clean thoroughly
Grease well
Wipe off excessive grease
Work TOB back and forth over splines and ensure adequate and even coverage
Old 09-10-2019, 04:46 PM   #6
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Following this.
I just heard this sound this morning but mine isn't as loud as OP describes. I had to turn off my radio to hear it. Clutch in, it's gone clutch out can hear it. I thought it was chattering from the new clutch.
I changed my clutch about 900 miles ago. Replaced the OEM Flywheel, SouthBend Stage 2 Daily, Exedy TOB, Verus Fork/Pivot, Motul tranny fluid.
Clueless
YamahaR86 is offline   Reply With Quote
Old 09-10-2019, 08:11 PM   #7
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Noise matches engine speed. Comes and goes with application of clutch. Recent clutch work.
Sounds like you're yanking that transmission again.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Clicking sound on startup radroach Issues | Warranty | Recalls / TSB 2 01-17-2019 06:55 PM
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
clicking sound? FR-Sky Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 11-26-2016 09:21 PM
Clicking sound when shifting into 4th? Marcbrz86 BRZ First-Gen (2012+) — General Topics 4 05-19-2015 08:52 PM
Clicking sound at idle from engine bay? l0aded Issues | Warranty | Recalls / TSB 2 08-13-2013 02:26 PM
