Old 08-12-2013, 07:58 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Clicking sound at idle from engine bay?
I feel like this may have been discussed before but there are so many threads about clicks from various parts of the car I figured I might as well make a new one specifically about the engine bay @ idle. Does anyone else have an intermittent sound at idle every ~15 seconds? The sound will go off and you can hear the engine sounding slightly different after the click before it clicks again in about 15 or so seconds and again changing sounds slightly. I believe the RPM might move ever so slightly too when this happens. This is at idle so I assume it wouldn't be a transmission or differential sound. It is pretty worriesome.
Might be worth noting that AC is on usually (I am not sure whether it happens when AC is off, will check when I can).
l0aded is offline   Reply With Quote
Old 08-12-2013, 08:17 PM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
It is most likely your A/C compressor clutch kicking on and off. That is perfectly normal.
Old 08-13-2013, 02:26 PM   #3
l0aded
Addicted
l0aded's Avatar
Yeah it was the AC, thanks for input. Now can I can breathe a sigh of relief my DI injectors aren't exploding. =p
ATfaint to moderate clicking sound in cabin Shimmyshake Issues | Warranty | Recalls / TSB 15 05-21-2014 12:26 AM
Clicking noise in engine bay teddydoggy Issues | Warranty | Recalls / TSB 4 08-12-2013 04:15 AM
Popping Sound While Idle distracteddev Issues | Warranty | Recalls / TSB 6 06-17-2013 10:15 PM
GTS rear left popping/clicking sound and fix. sigmaoctantis AUSTRALIA 11 05-19-2013 06:58 AM
clanking sound with idle wallace03 Issues | Warranty | Recalls / TSB 4 05-08-2013 05:19 PM
