Old 08-19-2019, 03:57 AM   #1
relentless717
relentless717's Avatar
Drives: BRZ STI 2019
alignment specs....is there a dedicated thread ??
I am a new guy to this forum............and happy to be here !!
I have searched and have seen a few posts about some individual alignment likes.... but I can't find a dedicated thread.....
Any help advising and directing me would be appreciated..........!!
Thanks in advance.......
Bill
relentless717 is offline   Reply With Quote
Old 08-19-2019, 10:59 AM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
Welcome!
There are several threads in the suspension forum, not a dedicated thread that I have ever seen.
Many of the guys in there are very experienced in track alignments, I learned alignments on an old optical Hunter machine 15 or so years ago, and have been doing them ever since.
maslin is offline   Reply With Quote
Old 08-19-2019, 05:49 PM   #3
86MLR
86MLR's Avatar
Depends on the track, depends on the tyres.
Look at your tyre wear
Infrared temp guns are cheap and will give a relatively good reading across the tyre, outside-middle-inside
Inside is usually tyre pressure
Outside higher inside lower = more camber
Yada yada yada
Test and tune, test and tune
For my street car I've gone down a bit from my last settings of -2.5° front -2.0° rear zero toe to -1.5° front -1.0° rear zero toe, I will gauge this by looking at tyre wear and handling
Tyre pressure is 35psi, tyres are RE003 235/45 17 on 8" RPF-1
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 08-20-2019, 01:43 AM   #4
relentless717
maslin and 86MLR .....Thank you very much for your feedback !!
I am really surprised that there is not more information about alignment setups.
All the best........!!
I don't track, but love agressive setups for running the twisties.....!!!
Old 08-20-2019, 03:16 AM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Alignments are just so specialized it's hard to say. I have included a baseline guide for spirited driving here though (along with lots of info on getting there) http://www.ft86club.com/forums/showthread.php?t=103609
Old 08-20-2019, 03:35 AM   #6
86MLR
86MLR's Avatar
There is some general rule of thumb settings
But, each car has different tyres, shocks, swaybars, tyre pressures, all of these factors will effect how your car uses its tyres
Track setting on a street car can be problematic, you will lose braking distance, and your tyres will never really get warm and sticky when you are driving to work, so the grip will not be optimised, same with tyre softness, a soft warm tyre can use more camber than a all season.
Street setting on a track will kill your tyres.
Back when I was tracking my cars would have multiple setups, street and track, different tyres, ride heights and alignment setting.
My street set up was easy, the track set up depended on what I was doing and where I was doing it
My Skyline ended up with 3 sets of tyres and rims, street, circuit and drag radials
Speaking of which, when I went to the drags I would wind in 0° rear camber to try and get as much tyre on the road as I could
Sounds complicated, you bet, I had my little black book with different setups for different locations, weather conditions, tyres pressures, did I go overboard, hell yes, but I found the whole thing part of the fun.
Nowadays I just hit the streets and do the occasional maaaad skid, I've always been a hoon, now I'm a old slower hoon
Old 08-20-2019, 07:32 AM   #7
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I'm far from a drag guy but I would have thought you'd want to go slightly positive camber for drag. When you get that initial squat off the line you'll get some camber gains in bump that I thought you'd want to account for.
EDIT:
for the OP, the most helpful thread I've found
It's in the suspension forum and for some reason doesn't appear to be a sticky (unless my coffee just hasn't kicked in yet).
CrowsFeast is offline   Reply With Quote
Old 08-20-2019, 08:09 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
It ain't hard but there's a lot of misinformation about...
Stock car, there's no camber adjustment, so zero toe all around and done.
Biggest shortcoming of stock car is near-zero front camber. This can be remedied to some degree with camber bolts.
For street car, spirited driving, I say get camber bolts and install for max negative front camber, and zero toe all around.
Done.
Old 08-20-2019, 08:49 AM   #9
86MLR
86MLR's Avatar
EDIT:
The old 33 didn't squat that hard
Circa 2012
Old 08-20-2019, 08:53 AM   #10
CrowsFeast
CrowsFeast's Avatar
Circa 2012
Oooo... Love me a 33.
Old 08-20-2019, 11:01 AM   #11
CrowsFeast
CrowsFeast's Avatar
Done.
I tend to advise against fully zero toe but rather a slight toe in or out depending on driving style and preference. I have slight toe in at all 4 corners but may opt for some toe out in front after some experimentation.
The reason for this is that quite often a car with zero toe all around will be less stable or have a tendency to wander while travelling down the road (sometimes felt as tram-lining). If the wheels are fighting each other slightly (either in or out) it tends to have a stabilizing effect (toe-in more so). Depending on your tires, local roads composition, personal preferences, position of earth relative to the sun, etc. you may not have the same experience so it may not matter but just my $.02
Old 08-20-2019, 06:17 PM   #12
86MLR
86MLR's Avatar
https://drivermod.ca/2016/01/29/how-much-camber/
Old 08-22-2019, 07:16 PM   #13
relentless717
Thanks .... !!!
Again, I would like to really thank all the people on this thread for their feedback !!
This is all truly going to help my getting an ideal setup.....up to including some suspension mods.
RS1 alignment specs DarkSideFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-08-2017 12:21 PM
Alignment specs Thatguyjeremy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-06-2015 01:49 PM
Dedicated Daily Commuter Thread Monogram Scion FR-S / Toyota 86 GT86 General Forum 66 01-25-2014 02:08 AM
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
Alignment specs? russv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-03-2013 10:16 AM
