Old 05-06-2015, 01:33 PM   #1
Thatguyjeremy
Drives: 13' Asphalt FRS
Alignment specs
If anyone is willing to help... What specs are you running with your wheels. I'm installing 17x9 wheels. Lowered on eibach sport lines, with whiteline front camber bolts, and spc lower control arms. Thanks in advanced
IG: __thatguyjeremy
Thatguyjeremy is offline   Reply With Quote
Old 05-06-2015, 01:43 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
what sort of driving are you doing?
Old 05-06-2015, 01:46 PM   #3
gramicci101
Off Topic
^ That's very important.
Also, what offset are your 17x9's? Since you're on springs instead of coilovers, room in the front can get a little snug. You may not be able to run the camber you want due to clearance issues.
Old 05-06-2015, 01:49 PM   #4
Thatguyjeremy
Mainly DD with a few "spirited" drives here and there. +35 offset
IG: __thatguyjeremy
Autox alignment specs? normanb21 Tracking / Autocross / HPDE / Drifting 18 02-12-2015 07:52 PM
Wheel pros, help me with these alignment specs from my shop. STS-V Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-30-2014 11:01 AM
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
Alignment specs? russv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-03-2013 10:16 AM
Actual alignment specs from BRZ taosracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 06-29-2012 09:33 AM
