Old 08-06-2019, 08:06 AM   #1
matwolb
Drives: Toyota GT86 '13
Ignition coils - '12 GT86 - P0351
Good morning FT86 forum members,
I'm just guessing if I could use forum's knowledge on our beloved cars here, for a question that has arisen in my mind after suffering a P0351 problem - CEL light in my dash.
I own a Toyota GT86 from 2012, so first of all I'm not sure if I should post here, on FRS / BRZ forum (I hope so as the car is almost the same). When reading all the info available on this forum for this error code, it seems I need to change the coil for cylinder 1.
Question arises when trying to find part number for the coil. According to Toyota, part should be SU003-00417. However, if I search for Subaru's one, it's 22433-AA652. As the first one seems to be more difficult to find, and more expensive, is there any known issue I should be aware of if I try to use Subaru's one on my Toyota? Price is almost half!!
Thank you very much,
David
matwolb is offline   Reply With Quote
Old 08-06-2019, 09:49 AM   #2
Crydo
Crydo's Avatar
Drives: 2012 GT86 Dark Grey
Hi Davin,
The engine should be the same in the BRZ/FRS/GT86.
just triple check if its indeed the part you need and if its for the 2012 engine
Crydo is offline   Reply With Quote
Old 08-06-2019, 10:06 AM   #3
Subaru uses a different part number system even though the parts are exactly the same. As long as the part number is applicable for a 2013 BRZ/FRS/86 it will be exactly the same part across the board. Use it without fear.
Old 08-06-2019, 10:53 AM   #4
matwolb
Thanks for your help guys! Really appreciated.
Before buying the coil, I'll switch my air filter back to stock one and test if I'm able to get CEL again - P0351 appeared on the same day I installed a drop-in filter from K&N (the rest of the car is full stock) and high revving (pretty darn easy to get it, just rev upper from 6K).
Does anybody know if there's any relationship between these events or is a normal one to see a coil failure at 46K Km? First one of my GT86 life...
Thanks & have a good day,
David
Old 08-06-2019, 11:13 AM   #5
David
There is a pretty comprehensive history of coil failures on the first run of these cars (2012 for you 2013 for us) so it isn't a surprise you threw the code. Shouldn't have anything to do with the filter so I wouldn't even worry about trying to change back.
Old 08-14-2019, 06:48 PM   #6
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
@Tcoat anyone know if there are compatibility issues between 2015 BRZ and FRS? i bought some coils for a 2015 FRS but I later realized that the 2015 BRZ isnt listed as compatible. just want to know if they can work or if they are completely different?
glorydays is offline   Reply With Quote
Old 08-21-2019, 02:55 PM   #7
Ronthebiker14
Ronthebiker14's Avatar
I remember reading somewhere that they updated the coil packs in 2015 but that they were compatible with all years and the updated one were better, but I would search that for yourself first. I replaced 2 of mine with the part number for 2013-2014 and wrapped all of them with heat shielding.
Ronthebiker14 is offline   Reply With Quote
Old 08-21-2019, 03:24 PM   #8
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
2012-2014 are a different part from the 2015+. The connector is different. This applies to both the FRS and BRZ models. Ex. If you have a 2014 buy the coils from a 2015 will not work. Easy way to tell the difference. The 2012-2014 will have a "straight" 3 prong plug. the 2015+ plug is triangular.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
cel, coil, p0351, subaru, toyota
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 04:05 PM
NO DIY for ANY ignition coils! Dr. BRZ DIY (Do-It-Yourself) Guides 6 07-16-2018 01:41 PM
Has anyone resolved their ignition coil CEL issues? (P0351, P0352, etc.) edward Issues | Warranty | Recalls / TSB 41 11-06-2017 07:48 AM
CEL P0351 Ignition Coil A Exrald Issues | Warranty | Recalls / TSB 16 03-23-2017 11:09 PM
Ignition Coils - Misfiring Help SmireyFase Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 11-10-2016 02:06 PM
