Old 02-21-2017, 01:26 AM   #1
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
NO DIY for ANY ignition coils!
why is there no diy for any ignition coils! i need a new ignition coil C but there are no diy's! could someone please write one up so i dont mess anything up. and diy for the other ignition coils too.
Dr. BRZ is offline   Reply With Quote
Old 02-21-2017, 02:12 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's pretty easy if you have skinny hands. The hard part is reaching the 10mm bolt that holds it in place.
Remove wire clip
Remove the 10mm bolt
Wiggle loose/ straight pull out.
Reverse steps for new coil pack.
It's pretty much the same steps to changing the spark plugs but with out touching the spark plugs.
FYI I would download the maintenance repair manual PDF there's all your DYI info you need.
Old 07-15-2018, 07:57 PM   #3
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Remove wire clip
Speaking of the maintenance repair manual PDF... mine is missing all sorts of stuff. Seems like it just covers common maintenance things, like oil, wiper fluid, brake fluid, and coolant. Doesn't have any instructions on other critical things that take much longer before you need to replace them, such as the fuel system, starter, water pump, oil pump, and timing chain. For spark plugs, they just tell you what kind to get and not actually the step-by-step instructions needed to change it. Couldn't find anywhere in the 428 pages.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 07-16-2018, 12:03 AM   #4
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Sounds like you got the service manual not the repair manual.
Old 07-16-2018, 12:29 PM   #5
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
This is a good video that outlines how to replace the coil pack:
[ame]https://www.youtube.com/watch?v=dM0aJzi81YM[/ame]
Lynxis is offline   Reply With Quote
Old 07-16-2018, 12:58 PM   #6
ermax
ermax's Avatar
I've pulled plugs without lifting the engine but after pulling my entire engine and seeing how easy it was I think if I need to access the coils or plugs going forward I will simply raise the engine. In the end I think it will be easier. I just rebuilt my engine and was planning on doing a compression test this weekend so I can see how well the rings are seating. I plan to do it the way the manual says to but if I find any shortcuts I will take note.
Old 07-16-2018, 01:41 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I just replaced coil #1 myself. It took less than an hour. It is not that hard, if you have small hands like me...
Good luck!
I LIKE TIRES!
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Ignition Coils - Misfiring Help SmireyFase Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 11-10-2016 02:06 PM
FRS Ignition Key ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 120 07-22-2014 09:23 PM
Ignition vs Argento? Pacific Auto Scion FR-S / Toyota 86 GT86 General Forum 3 08-17-2013 04:24 PM
Keyless ignition for my FRS Gixxersixxerman Electronics | Audio | NAV | Infotainment 1 11-30-2012 11:09 PM
