Drives: _
Need help with OEM sway-bar end links
I'm planning on replacing OEM end links with new OEMs. Suspension is all stock. Ride height is stock, and will remain stock.
Do I have to lift the car to do this job? Or can I just turn the steering and replace while loaded? |
Drives: 17 BRZ Series.Yellow
It's best to jack the car up a little, but can be done while on the ground.
Sent from my Pixel 3 using Tapatalk |
| The Following User Says Thank You to i8ur911 For This Useful Post: | chipmunk (08-01-2019) |
Fronts you can for sure do on the ground with the steering turned.
Rears are a bit more difficult with the car on the ground, so you may want to pull the whole rear sway bar out still attached to the endlinks so you can loosen/tighten the main rear endlink nut outside of the car. |
| The Following User Says Thank You to norcalpb For This Useful Post: | chipmunk (08-01-2019) |
If you do lift the car, you have to lift the whole end, not just one side. If you lift one side the sway bars will have a ton of load on them and you'll never get the new end link back on (assuming you can get the old one off).
Drives: _
Thinking of buying MOOG end links (part ID K750668)
https://www.carpartsdiscount.com/swa...l?3593=1326763 Any idea how this fares against OEM quality and longevity? |
Drives: _
No one's using/used MOOG K750668...??
Drives: 2016 Scion FRS
Bought some as spares. Didn't use them, but don't like how they feel at all. OEM moves much more freely.
Drives: _
#10 | |
Drives: _
Sent from a potato |
#11 | |
Drives: 2016 Scion FRS Release Series 2#439
I like the MOOG's better. They have grease fitting at both ends plus a wrenching point to hold the shaft rather than the 6mm hex which after time rusts and becomes useless to remove old links. Links do wear out so ease of replacement is a consideration. Although with the grease-ability of the MOOG's they may outlast the OEM style joints. |
| The Following User Says Thank You to Muskoka800 For This Useful Post: | chipmunk (11-21-2019) |
#12 | |
Based off experiences with other platforms, I would buy the Moog's with grease fittings without hesitation. |
#13 |
Drives: _
Got them $21 each on Amazon, free shipping. Prices immediately jumped to 30 after placing the order. Phew!
#14 |
Drives: _
Urgent! Which side does the washer go? On the nut side or ball joint side?
| Cutting Sway Bar End Links | mcrane | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 08-18-2019 09:41 PM |
| End links for TRD sway bars | Shindobaddo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-29-2019 03:28 PM |
| Adjustable sway bar end links | Dori_86 | Want-To-Buy Requests | 1 | 10-16-2016 02:07 PM |
| Help with sway bar end links | MisterSheep | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 09-29-2015 11:02 AM |
| WTB: Rear sway end links or sway bar with endlinks | JoeBoxer | Want-To-Buy Requests | 1 | 08-03-2015 01:20 PM |
