Old 08-01-2019, 09:31 AM   #1
chipmunk
Drives: _
Need help with OEM sway-bar end links
I'm planning on replacing OEM end links with new OEMs. Suspension is all stock. Ride height is stock, and will remain stock.
Do I have to lift the car to do this job? Or can I just turn the steering and replace while loaded?
chipmunk is offline   Reply With Quote
Old 08-01-2019, 10:40 AM   #2
i8ur911
Drives: 17 BRZ Series.Yellow
It's best to jack the car up a little, but can be done while on the ground.
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
The Following User Says Thank You to i8ur911 For This Useful Post:
chipmunk (08-01-2019)
Old 08-01-2019, 12:53 PM   #3
norcalpb
norcalpb's Avatar
Fronts you can for sure do on the ground with the steering turned.
Rears are a bit more difficult with the car on the ground, so you may want to pull the whole rear sway bar out still attached to the endlinks so you can loosen/tighten the main rear endlink nut outside of the car.
The Following User Says Thank You to norcalpb For This Useful Post:
Old 08-01-2019, 02:29 PM   #4
wparsons
wparsons's Avatar
If you do lift the car, you have to lift the whole end, not just one side. If you lift one side the sway bars will have a ton of load on them and you'll never get the new end link back on (assuming you can get the old one off).
flickr
Old 09-06-2019, 08:52 AM   #5
chipmunk
Drives: _
Thinking of buying MOOG end links (part ID K750668)
https://www.carpartsdiscount.com/swa...l?3593=1326763
Any idea how this fares against OEM quality and longevity?
Old 11-21-2019, 11:19 AM   #6
chipmunk
Drives: _
No one's using/used MOOG K750668...??
Old 11-21-2019, 11:33 AM   #7
steverife
Drives: 2016 Scion FRS
Bought some as spares. Didn't use them, but don't like how they feel at all. OEM moves much more freely.
steverife is offline   Reply With Quote
Old 11-21-2019, 11:42 AM   #8
chipmunk
Drives: _
Thanks for responding. Did you grease them first thru the grease fitting nipples?
Sent from a potato
Old 11-21-2019, 11:51 AM   #9
steverife
Sent from a potato
The pictures show grease fittings, but the actual part doesn't have them.
I've owned Moogs for other cars that had grease fittings and was very happy with them.
Old 11-21-2019, 12:01 PM   #10
chipmunk
Drives: _
An acquaintance who works at Tennecco said all MOOG parts must be greased before using, yea so if they don't have the nipples, they're probably worse than OEM. Tennecco owns MOOG (or maybe the other way around?)
Sent from a potato
Old 11-21-2019, 12:24 PM   #11
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I choose MOOG links to replace the OEM links which got destroyed trying to remove them during suspension upgrading.
I like the MOOG's better. They have grease fitting at both ends plus a wrenching point to hold the shaft rather than the 6mm hex which after time rusts and becomes useless to remove old links. Links do wear out so ease of replacement is a consideration. Although with the grease-ability of the MOOG's they may outlast the OEM style joints.
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
chipmunk (11-21-2019)
Old 11-21-2019, 12:26 PM   #12
steverife
Sent from a potato
Apologies. Looked at some old posts and my replacements are the K Power Rock Auto, with the same part number. I shopped against Moog and remembered the part number.
Based off experiences with other platforms, I would buy the Moog's with grease fittings without hesitation.
The Following 2 Users Say Thank You to steverife For This Useful Post:
chipmunk (11-21-2019), JohnJuan (11-21-2019)
Old 11-21-2019, 12:38 PM   #13
chipmunk
Drives: _
Got them $21 each on Amazon, free shipping. Prices immediately jumped to 30 after placing the order. Phew!Name:  20191121_115644.jpg
Sent from a potato
Old 12-07-2019, 12:43 PM   #14
chipmunk
Drives: _
Urgent! Which side does the washer go? On the nut side or ball joint side?
Sent from a potato
Cutting Sway Bar End Links mcrane Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-18-2019 09:41 PM
End links for TRD sway bars Shindobaddo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-29-2019 03:28 PM
Adjustable sway bar end links Dori_86 Want-To-Buy Requests 1 10-16-2016 02:07 PM
Help with sway bar end links MisterSheep Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-29-2015 11:02 AM
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 01:20 PM
