Old 03-12-2019, 05:43 PM   #1
Shindobaddo
Drives: Scion Frs
End links for TRD sway bars
What are some good end links for the TRD sway bar? I'm looking into PERRIN URETHANE END LINKS, are they any good and will it fit on the TRD sway bar. Thank you.
Shindobaddo is offline   Reply With Quote
Old 03-12-2019, 05:49 PM   #2
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Depends on the rest of your suspension setup.
CounterSpace Garage is offline   Reply With Quote
Old 03-13-2019, 12:30 AM   #3
Shindobaddo
Drives: Scion Frs
My suspension setup is stock so far. Going to get TRD sway bars front, rear and the TRD lowering spring soon. While I upgrade should I get the PERRIN URETHANE END LINKS?
Old 03-13-2019, 03:05 AM   #4
CounterSpace Garage
Stay stock until you figure out exactly what the issue is that requires you to change your end links.
The Following 3 Users Say Thank You to CounterSpace Garage For This Useful Post:
churchx (03-13-2019), FirstWinter (03-13-2019), wparsons (03-13-2019)
Old 03-29-2019, 03:28 PM   #5
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
end links
According to TRD details the bars come with new factory style endlinks.
PRODUCT DETAILS
Kit includes:
17.5-mm. alloy steel rear sway bar with polyurethane bushings
20.6mm 4130 solid front sway bar with polyurethane bushings
Factory-style ball end links
Polyurethane bushings and straps to hold the assembly to the FR-S or 86
Polyurethane replacement front sway bar bushings that fit the OEM sway bar and brackets
Finished with durable, gloss-red powder coat, which resists corrosion while improving appearance and durability
Muskoka800 is offline   Reply With Quote
FS: Cusco Strut Bars and Power Braces, Hotchkis Sway bars armyoffoo Brakes, Suspension, Chassis 10 08-08-2018 08:28 AM
FS: SoCal - Perrin F/R Sway Bars + RacerX Rear End Links *NEW* zAnSh1n Brakes, Suspension, Chassis 2 08-30-2017 09:38 PM
BC Racing, Whiteline Sway Bars, Kartboy Rear End Links, Carbotech, DBA@ OAKOS OAKOS Automotive Brakes, Suspension, Chassis 25 03-10-2015 12:55 PM
BC Racing, Whiteline Sway Bars, Kartboy Rear End Links, Carbotech, DBA@ OAKOS OAKOS Automotive Brakes, Suspension, Chassis 226 01-19-2015 01:46 PM
question on white line sway bars with end links Frs32907 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-27-2014 12:02 PM
