Drives: 2015 Subaru BRZ
Grind going into 3rd gear
Hi guys, I had this grind occur during my shift from 4th > neutral > 3rd
I was cruising around 4th gear at 40km/h and decided to put in neutral as I was coming to the stop light... and had the clutch in for a good 5-10 seconds, then all of a sudden the light turned green so then I decided 3rd gear would be best at 30km/h... as I was slowly pushing it into 3rd, I heard this faint grind so I backed off and put it in firmly with no issue. My question is... is this normal? and would the issue be I was holding the clutch in to long? so the shaft or gear (whichever is disengaged) slow down and not mesh? this was all done during clutch fully depressed on a 2015 Subaru BRZ 45k KM. thanks in advance
Hi @godbiggy and welcome to Ye Ol Forum -
![]() Yep, I reckon you confused your transmission gears and synchronizers. I would suggest that when you shift from 4th down to 3rd, just push in on the clutch, blip the throttle and move the shift lever - in that order - all within a 1-3 second time frame. If you would like a detailed explanation I will ring up ol @Ultramaroon for you and, if he not in a cranky mood, he will explain it to you. - ![]() humfrz |
ProCrastinationConsultant
to be clear, are you not rev-matching the downshifts? that's the main reason to have a manual!
i grind occasionally, today, i accidentally started from a stop in 3rd. it happens. just let the motor sing to redline to apologize
#4 | |
Hey Humfrz I see that you said blip the throttle and move into the selected gear, meaning rpms have a role in allowing the shifter to enter the gear? What I'm really just confused on is why did it grind when I had my clutch fully depressed? I never had this happen Thanks for replying tho
#5 | |
And when I decided to push it into 3rd it just had a faint grind, this all occurred during the clutch being fully depressed which is confusing |
i see. the simple answer is the revs fell too far.
the longer answer is the input and output shaft speeds became drastically different, forcing the syncro's to work harder, which created friction and more force on the gearstick lever. it happens to all of us, but it's generally something you don't want to make a habit of
#7 | |
I see ol @soundman98 explained "how it works" - https://auto.howstuffworks.com/manua...chronizers.htm humfrz |
Drives: 2016 Subaru BRZ
Sometimes mine grinds going into first, and acts like it wants to pop out. I’ve put about 5000 miles on my car since I got it though and haven’t really had any real issues. The gearbox is funky sometimes, but like everyone else said when down shifting you always want to give it some throttle. Also down shifting to 2nd gear make sure you’re not over 50mph or you’ll probably be in a bad mood for the rest of the day.
Drives: 17 Asphalt 86
I notice sometimes 2-3 shift sounds a little crunchy like a grind.
I think it mostly has to do with a lazy shift, and not being 100% on the floor with the clutch. |
#10 |
Drives: 2014 GT86
If grind doesn't repeat, non fully disengaged clutch is one of most probable reasons. Slight clutch drag - synchros not working well to even out speeds, and here you go, gears grind.
#11 | ||
#12 |
#13 |
#14 |
ah, didn't they drop the final drive ratio in '16? i want to say they did, which would then make sense..
| 4th gear grind | dallenj | Engine, Exhaust, Transmission | 15 | 06-03-2016 04:04 PM |
| 4th gear grind | aaguirre123 | Engine, Exhaust, Transmission | 8 | 08-03-2015 04:58 PM |
| 5th and 6th gear grind... | Basket Case | Engine, Exhaust, Transmission | 7 | 02-11-2015 08:53 PM |
| Grind Into 5th Gear | Since885 | Engine, Exhaust, Transmission | 8 | 01-18-2015 05:47 PM |
| 2nd gear grind (yup another one) | SmartedPanda | Issues | Warranty | Recalls / TSB | 17 | 09-10-2014 04:02 PM |
