Old 07-14-2019, 01:22 AM   #1
justin6280
justin6280's Avatar
Drives: 2015 FRS
BRZ Turn Signal / DRL on FRS Wiring Help
Hey I recently converted my FRS front end to a BRZ front end. I bought the daytime running light strip/turn signal that sits above the fog light on the brz and plugged it directly into the FRS turn signal connector. The problem is, the BRZ drl/turn signal light only turns on when I am actively using the blinkers/hazards. Is there a way to have it turned on at all times AND flash when I blinker/hazard? I tried looking at a wiring diagram posting on the forum, but unfortunately I don't understand how to read it.
Here is a link for the FRS turn signal http://www.mediafire.com/file/38i78t...ning+Light.pdf
justin6280 is offline   Reply With Quote
Old 07-14-2019, 02:12 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
You would need to wire in a relay. Use the NC/C contacts, powering the drl from the drl circuit, and use the turn signal wire to trigger the relay
Old 02-20-2023, 10:36 AM   #3
GKevin61
Drives: 2013 White Subaru BRZ
How did you manage to connect it. I also have an frs bumper on my BRZ and I bought the turn signal lights that sit above the fog lights but the wiring is completely different for the bulbs. It's been a while since I looked at it but I'll look again to clarify more.
GKevin61 is offline   Reply With Quote
Right side turn signal does not turn on Feargt86 Issues | Warranty | Recalls / TSB 4 10-02-2018 01:10 PM
Turn signal wiring and fusing questions Mr_Eyo DIY (Do-It-Yourself) Guides 1 07-19-2018 10:54 AM
Turn Signal Wiring and lights DGM-BRZ Cosmetic Modification (Interior/Exterior/Lighting) 6 07-20-2016 11:33 PM
Turn signal wiring OURO3OROS Cosmetic Modification (Interior/Exterior/Lighting) 0 04-06-2014 10:05 AM
