Old 07-20-2016, 12:41 PM   #1
DGM-BRZ
DGM-BRZ's Avatar
Drives: 2017 CWP STi
Turn Signal Wiring and lights
A few questions actually
1. Would a 15cm long bulb fit into the oem turn signal
casing? For the FRS
2. Do i need to take off the entire front bumper to reinstall a completely new oem turn signal wiring and everything?
DGM-BRZ is offline   Reply With Quote
Old 07-20-2016, 04:27 PM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
1. you know 15cm is really long. it wont fit even headlight bulb.
2. NO!! have you opened your hood and locate your bulb? you can reach them no problem
Old 07-20-2016, 04:36 PM   #3
DGM-BRZ
DGM-BRZ's Avatar
The turn signals
are above the foglights. Not the headlights like the Brz
Thanks
Old 07-20-2016, 04:39 PM   #4
zc06_kisstherain
Drives: SWP BRZ
Originally Posted by DGM-BRZ View Post
The turn signals
Thanks
I was confused. i get it now.
i still dont think 15cm bulb would fit.
for bulb changing, i think you need to pry plastic cover from front or access from fenderliner
Old 07-20-2016, 04:42 PM   #5
FX86
casing? For the FRS
i fit a 52.18mm led bulb into the oem turn signal housing which converted to cm would be 5.218cm and it's almost close to touching the housing
a 15cm bulb would not fit honestly....where did you find such a long bulb?
Old 07-20-2016, 04:45 PM   #6
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
No it wouldn't fit. That's approximately 6" long.
kmbkk is offline   Reply With Quote
Old 07-20-2016, 11:33 PM   #7
DGM-BRZ
DGM-BRZ's Avatar
Im stupid. I made the typo twice. I meant 5.5cm. And it fit lol, already installed haha.
Got stupid bright LED's.
Turn signal lights whip Cosmetic Modification (Interior/Exterior/Lighting) 13 02-26-2015 10:45 PM
Is there another way to keep the turn signal lights on? DeadStar7 Scion FR-S / Toyota 86 GT86 General Forum 10 06-29-2014 10:43 PM
Turn signal wiring OURO3OROS Cosmetic Modification (Interior/Exterior/Lighting) 0 04-06-2014 10:05 AM
WTB FR-S Turn Signal Lights retrosmiths Want-To-Buy Requests 2 01-08-2014 02:13 PM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
